Strange. Have you tried changing the output channel to some other range? Maybe a different frequency would not give that same problem.Ok, so I want to split the signal from a TV 2 from my 722 to go to another TV. I thought it was as easy as going to walmart and buying a simple splitter. Well when I hooked it up, the picture quality on the 3rd TV is really bad, until I turn the 2nd TV off. So there seems to be some sort of feedback going from the 2nd TV to the 3rd TV. Is there anyway to filter this? I tried the seperator too, included with one of my 722's, and that just produces a snowy picture on the 3rd TV. So not sure what I need...
the seperator is not a 2 way splitter it is designed for DPP technology. For use as a way to seperate the signal from the dish. Check all you ends, if you have a wire braiding wrap this will load down the signal and give you a poor picture. try one Tv at a time until you find the bad wire.
HmmOk, so I want to split the signal from a TV 2 from my 722 to go to another TV. I thought it was as easy as going to walmart and buying a simple splitter. Well when I hooked it up, the picture quality on the 3rd TV is really bad, until I turn the 2nd TV off. So there seems to be some sort of feedback going from the 2nd TV to the 3rd TV. Is there anyway to filter this? I tried the seperator too, included with one of my 722's, and that just produces a snowy picture on the 3rd TV. So not sure what I need...
Make sure you have a 2-way UHF/VHF splitter and not a VHF-UHF bandpass splitter. The latter will be labeled with separate UHF and VHF ports and is for mixing or separating those signals for old TVs or separate antennas. It should say -3.5 to -4.5 dB to each output from the input (-3.0 would be the ideal). If you use a bandpass, only the UHF leg will work with the Dish output.Ok, so I want to split the signal from a TV 2 from my 722 to go to another TV. I thought it was as easy as going to walmart and buying a simple splitter.
