Advice on Vertical Antenna 40 -10m
spongella
1,625
1,236
Central NJ
Am a dyed-in-the-wool vertical man, used Cushcrafts, Hygains, and currently have an S9 vertical that is beginning to show it's age. Was wondering who uses a vertical for amateur HF and which they like?
The S9 vertical is simply a telescoping 43 foot fiberglass mast with a wire running up the middle, simple design, and works well with a tuner. They are not made anymore, at least the longer ones.
Thanks!
Maybe this antenna:
43 FOOT 10-160 METER MULTIBAND FOLDOVER FREESTANDING VERTICAL ANTENNA 5KW UNUN
The 43 foot 10-160 meter Multi-Band Vertical antenna is a freestanding vertical element with no traps or coils.
Big 2 1/8" bottom section tapers at the top to 3/8 of inch for flexibility, strength and wide bandwidth.
A custom CNC machined 2" solid super heavy duty black Delrin base insulator for superior UV resistance and high power handling capability.
A 3/8 thick Aluminum foldover plate are included for easy one person raising/lowering no-bind tilt-over action.
This package includes a 5kw 4 to 1 UNUN matching transformer.
A minimum of 16 radials is suggested for good performance.
The installation PDF file for this vertical can be downloaded from this page.
See attachmentsOverall height--43 Feet Includes foldover mount Includes all ss clamps Includes our 5kw matching transformer and mounting kit.
Bands of operation--10-160 Meters
Power rating--5KW ssb
Wind handling--92 MPH
no iceSWR-1.5 And under with customer supplied tuner at the operating position
NO LOSSY TRAPS TO BURN OUT AND FILL UP WITH WATER
Recommended coax length--100 to 150 feet
The buyer must sign for this item upon delivery
http://www.zerofive-antennas.com/pr...ldover-freestanding-vertical-antenna-5kw-unun
Reactions: spongella
Thanks for the heads up Technicoloco, this looks like a perfect replacement. To echo the other's comments, darn good price too.
I have not been active on HF in about 7 years, but when I lived in IL I had limited space so I used a Gap vertical antenna and also used an Isotron 40 meter antenna and surprisingly the isotron worked almost as good as some dipoles I've used.
Sent from my Z932L using the SatelliteGuys app!
