Antenna
jqueasy
3
Hey everyone first post, been reading for a while though, anyway I have a quick question, I live about 45 minutes outside of tampa and currently I have a powered antenna hooked to my 722 receiver and I receive all my locals except CBS which their broadcasting tower is about 45 miles away. I am looking into buying a larger outdoor antenna which I will place in my attic which i know will cut down on my signal strength, any of you have any ideas which antenna would give me the most bang for my buck, I would prefer an omni-directional one
Thanks!
Thanks!
A larger outdoor antenna in the attic is the right approach. However, large outdoor antennas are directional.
If you want more than one market you'll need two antennas with an A/B switch or one antenna and a rotator. A rotator will work in the attic if you have enough room.
Here;s what i used to solve my problem RadioShack.com - Home Entertainment: Accessories: Antennas: Outdoor: Low-Profile Omnidirectional Amplified TV Antenna
It is in the attic hanging from a 24in drop rod that is hooked to the ridge beam and i can get locals from 60 miles with it and it is omni like the OP was looking for hope this helps it did for me.
What the? I just bought that one, and I was unimpressed. I used to to replace my Winegard Sensar, and it was no better, and maybe even a bit worse!
Which is EXACTLY why I stopped going to Radio Shack years ago. Generally speaking from my perspective: RS = Overpriced and underperforming.
Well i have heard mixed reviews about the antenna and it is funny that you say a winegard sensar that is what this replaced and have had many other OTA antennas and this is the best one i have ever owned.
One thing i did before installing this antenna was put in all new cable (RG6 not that my old cable was bad) with no spices just one solid run at around 100 ft as it has a power injector so i figured new would be better to pass the power and signal.
This antenna does not work well with RG59 cable hope this info helps if you have older cable installed.
If it does not look like an antenna then you can probably count on it not performing like one either.
More Sophisticated Antennas Required
Thanks!
As spending tightens in these uncertain economic times, discretionary purchasing has shifted away from other key market categories, to consumer electronics and particularly to digital TV and HD. High Definition Televisions bumped digital cameras out of the top spot for the most desired CE product for 2007. Several dynamics are affecting millions of households now relying on analog signals for reception of their broadcast TV signals, with antennas older than 2 years. They need to upgrade to the new antenna technology, along with cable and satellite customers looking for alternatives. This has resulted in tremendous sales increases of OTA antennas for Antennas Direct. Although cable and satellite program providers will continue to serve the great majority of homes as the primary signal source, missing HD local reception, higher costs, billing add-ons, service outages, contact difficulties, in-home service waits and no shows have left many subscribers looking to OTA antennas as alternatives and backup.
Richard Schneider, President of Antennas Direct said “Our antenna sales for the first two months of 2008 are up 125% over this time last year, a year that in itself that was up 60% over 2006. The simple fact is that not all antennas are equal, some are better and some are the best for particular reception situations. This shift in consumer spending could not have come at a better time for us, because of the tremendous improvements in our Off-Air antenna technology and design that have taken place in the last few years, allowing us to offer the best OTA antennas for the HD revolution.”
According to an article in Ad Age “As Giant Retailers Reel, Marketers Gird for Worst”, as to Consumer Electronics, the news appears very positive. “Consumers seem to have designated technology as a new necessity, along with food, gasoline and home-heating oil" said the Consumer Electronics Association’s group economist, Shawn DuBravac. Ad Age continued “Forecasts for 2008 from the CEA and other CE researchers such as iSuppli bear that out, with predictions of overall electronics growth.” "Last year, when oil prices were going through the roof, we saw that people said, 'Since we're not traveling, let's spend some of that money on buying a flat-panel TV,'" said iSuppli analyst Riddih Patel.
There are more than 40 million households currently receiving OTA analog signals in the U.S., according to new proprietary research just released by Centris (Home), a leading market research firm. They said this number represents a “large opportunity for…manufacturers and distributors of "smart" television antennas…requir(ing) …more sophisticated (OTA) antennas.” Centris surveys reveal that 75% or more of over-the-air households have only set-top antennas. “The effect will have extensive ramifications, not only among consumers, but also electronics retailers and manufacturers who can expect an influx of costly returns when it is realized that the converter boxes and new digital TV's don't work," says Barry Goodstadt, Senior Vice President of Centris.
To viewers already receiving a cable or satellite network, the benefits of Off-Air antennas are compelling. There is only so much room on cable or satellite bandwidth in which to squeeze signal, so data is compressed to fit, resulting in a somewhat "soft" picture. An OTA signal is the gold standard in digital reception because it's almost completely uncompressed and also FREE. Local digital TV broadcasts are everywhere. But bandwidth limitations force cable and satellite providers to not carry all local channels in many areas, or may not offer all of them in high definition. Contract disagreements between local cable operators and local broadcasters mean that major networks may not be available in several areas. DISH Network® offers local HD coverage to about 47 percent of U.S. markets, while DIRECTV® reaches about 76 percent, but for an additional monthly fee.
“What about those other millions of viewers who want to see their favorite local shows and in HD” asks Schneider? “The answer is to add an OTA antenna to other signal reception sources”. This not only gives a viewer the ability to receive all their local stations, but, with the right digital antenna and location, some viewers may even be able to receive out-of-town channels, carrying blacked out sports programs or network broadcasts not available in their home town. As an added benefit, an OTA antenna provides back-up reception options for local cable or satellite signal loss due to equipment failure or rain, snow and ice fade and to smaller TVs and second sets in homes not wired for whole-house signal distribution.
