Titanium Satellite ASC1 and C1PLL damaged by Lightning.
Conway
270
239
Help! Lightning struck near by and took out my ASC1 and my C1PLL LNBF.. does the ASC1 have a replaceable fuse. Thanks!
Fuse is not blown. So I assume it's going to be my main board.. Brian are there any parts left over for the ASC1? Thanks!
Disconnect the ASC-1 from EVERYTHING external. Unplug it. Leave it overnight, then try it again. That may work.
As for the LNBF, it's probably fried for sure.
Power supply is working. I can hear it humming. Surge came in through the coax from the LNBF. Display is dark and no response from the front panel buttons.
Reactions: primestar31
Lightning damage may be contained to a single component or damage multiple PCBs and/or the display. Best to send the complete unit in for bench testing. Will advise on repair.
If it is advised to repair, shipping is likely the most expensive consideration.
Email: support@titaniumsatellite.com
Thank you for your reply! Do you charge a flat fee for repair?
OTHER Reactive power
Edision How do I scan a transponder without wiping channels?
Who Read This Thread (Total Members: 7)
