azbox remote control by mortimer login trouble
BattleOP
19
I am tying to use the AZBox remote control by mortimer software to control my AZBox. The problem is that if I enter my root/password combination into the Remote Software I get:
Connecting to 10.10.10.5:23...
AZBox login: root
Password:
Login failed...
However if I use putty to Telnet or SSH to the box using the same root/password combination I get right into the box.
Any ideas?
It's enabled. That's why I can telnet / ssh from Putty but when I try to connect using the remote software I get an invalid username/password error.
It would help to know which azbox and what firmware your using so what I am going to say is just a shot in the dark.
If your using the Ultra or Premium/plus azbox with official firmware then first make sure ALL your network settings are enabled.
SSHD = enabled
FTP Server = enabled
File Server = enabled
Dynamic DNS = enabled
Telnet Server = enabled
Now for most programs I have seen, (I have not used the one you mentioned)....
FTP Port = 21
Telnet = 23
Login = root (all lower case)
Password = azbox (all lower case)
Try this and see if it works.
oh, make sure your internet connection with the azbox is setup properly too.
(just trying to cover all the bases for you)
I started with 9.5306 and upgraded to 9.5402 on a Premium HD+ with all services enabled. It didn't work before or after the upgarade. I had also changed the root password from the default and made sure I was using the same in both places. Using Putty it works, the remote control it does not. I changed root back to the default azbox password and it still does not work.
possible bug: weird blind scan results
Want a Black Screen for Radio Mode on the microHD?
