best dish and lnb
hbilt
24
biscayne park(miami,Fl)
I live in South Florida and rain fade is a big problem. I have 1 500 dish for 110 and 119 and another 500 for 61.5. I have 2 HD receivers with 4 inputs(1 split for each)
If I separate the 110 and 119 into 2 dish 500, what lnb and how would I hook them up.
I I buy 3 Wingards or fortec, what lnb do I use and what holders will work on the dishes.
Since you have HD receivers, you can go with the Eastern Arc 61.5, 72.7 and 77. The EA dish is the 1000.4 dish which has a Dish Pro Plus LNB that requires only one cable to your receivers which I am assuming that is what you currently have now. If you want to go with a slightly larger dish, you can go with the 1000.5. I am only familiar with it from what I've read, but the 1000.5 is basically the dish 500 plus dish with a repoint kit for EA and uses the existing LNB. This may be your best option, then you won't have to mess around with switches and other hardware.
Dish Network HD Packages
612 loud in the middle of the night
