J jagee SatelliteGuys Guru Original poster Apr 16, 2007 149 0 May 5, 2007 #1 If my pansat receiver isn't set to the right Diseqc like for C band it says 1 and KU band it says 2,Will i not take in any transponders.I left it set at none.Is that why i might not be able to set up my dish and receiver
J jjpicou SatelliteGuys Family Apr 26, 2005 55 0 Ohio May 5, 2007 #2 If you are using the BSC621-2 LNBF,you will need to assign Diseqc 1 for C band and Diseqc 2 for Ku Band on your receiver.
J jagee SatelliteGuys Guru Original poster Apr 16, 2007 149 0 May 5, 2007 #3 So i won't receive any type of signal until i do?Is that right.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,361 14,743 Mankato, MN May 5, 2007 #4 pretty much. I tried one time without selecting a DIseqc port and got nothing. I knew it was aimed right as I just swapped LNB's from a working system
J jagee SatelliteGuys Guru Original poster Apr 16, 2007 149 0 May 5, 2007 #5 ill try that later on Ive been beating my head and not doing it the right way LOL
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,361 14,743 Mankato, MN May 5, 2007 #6 also make sure about the skew. I know on mine it was off by like 90 degrees for some reason
