C2 lost most of it's reception, except for the Caribbean mux on G16 and a couple of other strong TPs on other sats. Replaced it with a 741 c/ku unit I had in storage, all is back now except for my second receiver.
Took the cover off of the C2 and found a lot of white residue on the circuit board, like water had infiltrated the unit and subsequently evaporated leaving the evidence. The electronics was still working so I think there might be a chance to resurrect the board by cleaning the residue that may be ever-so-slightly conductive.
I am thinking of doing the following:
1) wash circuit with distilled water (without removing from feed horn) & let dry for a few days. Might dissolve the resedue?
2) Spray with circuit/contact cleaner
3) re-grease seal and re-assemble
Not sure if it is easily possible to remove the circuit from the feedhorn without de-soldering the probes. The back side of the board likely has residue on it too, hence using the distilled water routine... I suspect the probes are glued into the feedhorn and the board mounted after, then the connections soldered.
Has anyone done this before, or have any better ideas?
-C.
-C.
