Campground hook up
Chris04626
118
MAine
I have a dish 1000.4 connected to a solo node than cable from node to host hopper and cable to client Joey. My neighbor here can't get signal too many trees in his way. He wants to run a cable from my set up to his camper. Is this possible anyhow he has a regular receiver not a hopper
how would I go about it?
You should be able to run a third line from the dish (I believe it should have 3 outputs) to the camper as you cannot run it off the node. If you don't have a third output at the dish, you can connect a DPP33 or a DPP44 switch at the dish and connect everything from the switch.
My 1k4 dish is currently shared by a Hopper/Joey and a VIP211k. Ports 1 and 2 on the LNBF go to the Solo Node, and port 3 goes to the 211k.
He shouldn't be using all three outputs.. The solo node only needs two running to it off the lnb. Port 3 should be open..
Virtual Joey on LG TV's - How seamless is it?
Not picking up sat 72
