Can you use a dp44 and a 34 switch in the same system
jdodson
25
I would like to use the 44 swirch and then branc of with the 34 switch. Us the 44 for the dual tuners, and the 34 for the singal
thanks
Yeah put the DPP44 first and you will be fine, with DP or DPP LNB's.
In addition to what they said above....
If you use the DishPro Plus Twin LNBF:
- It must be connected to Ports 1 and 2, which will default to Port 1 = 119 & Port 2 = 110.
- Once you connect the DPP Twin to a switch, the input port will be disabled, so you will have to connect your wing dish to the DPP44 Port 3.
It sounds like you probably don't have a 4th satellite position, but are only using the DPP44 so that you can run single cables to your dual tuner receivers; and you have more than 4 receivers, so you are adding the DP34 to the side of the DPP44.
If any of your single tuner receivers are legacy receivers, then you will either have to directly connect those to a DPP44 switch, or to a DP34 switch using a "DP Adapter".
