Captions
  • WELCOME TO THE NEW SERVER!
bjohn
92
Is there anyway to turn the captions on/off easily on the 811 rather than going into all the menu selections?
I can't turn off the CC
:mad: In my case, I tried everything in the book and I just can't turn off the caption. I wonder if others are having the same problem.
Mine will always disappear in one or two days, even I tried to leave it on. The ony way it will re-appear is to unplug and plug it back the 811
Do you have your audio going to a receiver? Do you mute your TV? If both are true, try taking the mute off of the TV and just bring the TV sound level down to zero. Many TVs go to auto caption when in mute mode.
My 811 was doing it on SD channels, but not HD channels.
Captioning was "off" but I still couldn't get rid of the captions.
It hasn't done it in awhile actually, hmmmm wonder why?
I don't believe that the 811 passes the CC info through to the TV, when using an HD out. That is why one needs to turn captions on using the 811, where it is decoded internally.
