Is there anyway to turn the captions on/off easily on the 811 rather than going into all the menu selections?
bjohn said:Is there anyway to turn the captions on/off easily on the 811 rather than going into all the menu selections?
hyoshim said:In my case, I tried everything in the book and I just can't turn off the caption. I wonder if others are having the same problem.
Same situation with mine.pxxv23a said:Mine will always disappear in one or two days, even I tried to leave it on. The ony way it will re-appear is to unplug and plug it back the 811
I don't believe that the 811 passes the CC info through to the TV, when using an HD out. That is why one needs to turn captions on using the 811, where it is decoded internally.Bobby said:Do you have your audio going to a receiver? Do you mute your TV? If both are true, try taking the mute off of the TV and just bring the TV sound level down to zero. Many TVs go to auto caption when in mute mode.
