Carbon UI for Hopper2000
Is the H2000 active on an account? CUI should be the only software available.
Reactions: JSheridan
"Offering?" "Forcing" is more like it.
Count your blessings and don't bring it down upon yourself. If I could dump it and go back to the previous software, I would.
There was a message about a month ago that they were going to stop updating those. Maybe they actually did something that they said they were going to do
That's more like it, get it before on other H2000
I installed a lot of receivers with CUI, I don't have any problems, most of the slowness is worn out hard drive
110,119 & 118
The reason I asked is that maybe they moved the download but if you're getting 110 and 119 you should be getting the download stream. Have you tried the boot recovery?
Boot recovery, changing hard drive, sleep mode, just about everything
WOW, if a boot recovery didn't get it then it must not be there. Did the boot recovery finish? I noticed that lately the boot recovery takes a very long time but does eventually finish with the latest production software.
Maybe no more CUI for H2000, thanks for your help
You're welcome. I can't see Dish doing that because if they did then customers with multiple Hopper 1's and 2's won't be able to share recordings between receivers, etc. That would be a mess.
One more thing you might try if you haven't. If you have another Hopper 1 or 2 then you might try connecting them on a MoCA network. The one with the old software might download the update from the CUI one.
I have to download a Hopper 1 in the next couple of days and I'll let you know what software it takes. We're on eastern arc 61.5 and 72 here but if it's still on this arc then it should still be on the western arc too.
Good luck.
Reactions: trojan67
Joey won't release tuner after use.
Wrong sat message
