Channel Surf Reboot Bug
WeeJavaDude
766
SoCal
To try and get a better handle on this one. I thought it would be good to move it to its own thread. This seems to be the biggest issue with 2.82. What I think would be good if we can try and find some commonality here for the people that are having it. If you are running into it, it would be great to add an entry with your experiences. If you could include the following and anything else you feel necessary
1) What is your boot version. LADD??? LABD??
2) How long have you had your 811?
3) Any major stability issues since you had your 811?
4) Are you using the UHF remote that shipped with the 811 or a universal?
5) Are you using the channel locking feature
6) Do you have favorites configured?
7) Are you using OTA? Are you having any other OTA related stability issues?
8) WHat are you doing when the problerm occurs? (Steps to reproduce it)
9) How often is this occuring. (every time you surf? once a day?)
10) Have you had your 811 replaced before?
Well There is a few that might help narrow things down. Also if you are not having this issue, post your boot version and if you coudl answer the questions above too that pertain it will be helpful too.
I will start
Need to get that when I get home.
December of last year.
Not recently. Did have some when first purchased
Universal remote Pronto 3000. I did try and reproduce this with the UHF, but was not successful.
No
Yes.. I have 3 sets with about 20 in each.
Yes. Have 12 OTA channels. No stabillity issues with OTA. My OTA is rock solid.
Cannot reproduce it.
I have not seen it.
No
Here's my situation.
< Boot: 1013LADD Software: P282LADD-N >
< About 8 months >
< Rare BSOD. Biggest problem was whenever I tuned to my local PBS-HD channel it would get the 49% signal strength and it would take 5 min or more to lock >
< The stock remote that came with the receiver >
< No >
< Yes 3 categories >
< Yes. Occassional framerate slowdown / frame drop. >
< More often than not I just have to go to my PBS-HD channel. It doesn't matter if it is from a sat channel or an OTA channel. It will usually show 49% on the signal strength meter. Then after the window clears if the signal strength goes to 0% then it willl lock and I have to reboot the receiver. If it goes to 80%+ then the channel is ok. But, more often than not it locksup the receiver. >
< It happens everyday, almost, everytime I go to the PBS channel. I have gotten to a point where I avoid going to the PBS-HD channel. >
< Yes, the original receiver had such old firmware in it that it would not take the download forom the sat when it was installed. Dish sent me a replacement. >
mike
*<Strap 1013LAFD> <Firmware P282LAFD-N>
*June 2004
*Used to get random often Sat Aquisitions <cleared up with P269>
*Used to get often slo-mo reduced frame rates <cleared up after I added UPS to 811 and Power inserter>
*Used to get frequent BSOD <Not since P282>
*Lost some distant OTA digitals to 49% lock with P280 <Got back in P282>
*Used to get random self reboots <haven't seen since P269>
*Used to loose Audio/Video sync <Fixed in P280>
*Randomly resets remote address to 1 <This is the neighbor screwing wth me, Scott posted a hidden address range, don't think I'll have this issue anymore.>
*Still see pixelation breakups in HDTV delivered thru Dish.
*Mostly the UHF Pro 8.0 that shipped with the 811, but I have used a Blue button 1.5 IR, IR blaster from PVR and TV, and TV IR remote. Getting Pronto TSU7000 in a couple weeks.
*Not anymore, I have found the more personalization features you use the more likely you are to have an issue downloading firmware or your more likely to see bugs....I find the 811 most likely has a memory leak and the more memory you allocate to personal settings the more likely you re to see issues. (OPINION)
*Yes.. I have 2 sets 1 with about 50 and one with 6.
*Yes, I have 13 Digital OTA channels mapped. No subchannel information is displayed in EPG but the way the system gets it's info this is not a possibility at this time. I have had no OTA issues in this firmware revision...Yet.
8) What are you doing when the problerm occurs? (Steps to reproduce it)
*Cannot replicate it.
*I have not seen it.
*No, I am on my first 811.
Jason
All are 1013LADD
Too long
BSOD on all but one if left on an OTA channel at top or bottom of hour (guide update times?)
Both
NO
NO
Yes, No problems with OTA reception 95% or higher signal on all. Except the one with
282 just had blackout & auto reboot when checking signal strength on OTA.
using up button to go thru OTA channels
I don't usually do that, so this was first time.
No
LABD
~year
No major issues prior to 2.82
universal
No
Yes, 4 sets
Yes, only for digital. No stability issues. Most at 75-85%
Usually occurs when surfing up (from ESPN HD to local PBS HD). Not consistently reproducible. Tried the "factory reset" and reprogramming all locals and favorites with minimal change.
First couple of days with 2.82, occuring multiple times and could reproduce easily (every time, had to reboot or let 811 reboot on its own). Now, usually does not recur once rebooted until turn off 811 and turn back on (usually a few hours later or the next day).
No
mnb
Software: P282LADD-N Boot: 1013LADD
Jan/2004
Occasional BSOD. Also a rare and temporary disappearing color (color washes out and comes back in ~30 seconds). And lastly, no Dolby 5.1 (I have one of those receivers that doesn't detect whatever is sent out of the 811).
The remote that came with the 811.
5) Are you using the channel locking feature?
No
Yes. All 4 categories.
Yes. The well known 49% problem.
Channel surf on OTA Digital Channels...press up/up/up then boom ... reboot. This problem does not occur on OTA analog stations.
On further note, the only channels I surf on have a better than 65% signal strength.
Everytime I surf. Very consistent.
Yes. When I first received the unit, the DD 5.1 was not working and I called it in. They replaced it and that did not cure the problem. At this time, I did a search on the web and found this very helpful forum. I discovered that the DD 5.1 issue had to do with the type of signal that is sent out of the 811. There are two types and my receiver happens to not recognize what is sent out of the 811. There is supposedly a fix sometime in the future.
Software: P282-LABD-N
Boot 1013LABD
~ 1 year
Use to have the slow down bug. No longer have it
Using original remote
No
No
I have about 10 OTA channels all digital.
Channel surfing.
Before 282, BSOD would happend when going from OTA channels to HD channels. I had to reboot the receiver myself.
Since 282, BSOD is occuring in OTA channels that have not locked on (49% or less). The receiver now reboots itself.
Every time
10) Have you had your 811 replaced before?\
No
Hey who's moving my posts around here ;)
Fine I'll do this official thing although all the questions aren't nessecery.
Well I'm part of the LADD club
February 2004
Searching satellte when pressing guide on OTA (fixed)
BSOD and random reboots (fixed)
stock
no
not anymore
Random drops of video, dunno if it's MP or the tuner.
Channel recall between 2 OTA channels
Quick channel change between OTA channels.
Just once. I did a restore to factory defaults in menu, and it's gone.
nope.
Well from the posts so far, It does not look like there is a clear pattern. The one that I find most interesting is the person that relates the issue to a specific channel. Wonder if the bug that was created is channel specific and that is why we are not all seeing it. However, based on the other posts this does not seem to be the case.
The only common thread is the difficulty the 811 seems to have with showing all OTA channels correctly. If one were to watch only the satellite channels, one will no longer experience BSOD..
Franzius
I've been out of town for awhile. Here's my input:
Boot 1013LABD
~ 11 months
Use to have the slow down bug. No longer have it.
No
No
I have about 8 OTA channels all digital. All of my OTA was rock solid until 282.
Channel surfing. Only occurs when surfing OTA. This has happened on more than one OTA channel, but always when signal meter is less than 50%.
Every time
No
my info..hope it helps..
Software: P282-LADD-N
Boot 1013LADD
~ 10 months
black screen and no picture, would have to hard boot
No
removed them yesterday after going to factory reset...No help
I have about 7 OTA channels (depending on whether public TV is up. Seemed fine until the 282 upgrade.
Channel surfing from or to OTA channels. Happens on all OTA's but usually right before a big play! OTA sugnal strength
doesn;t seem to be an issue.
EVERY
No
A guess a question that should be added would be. Do you have Signal Strength issues with any channels you have added to your Guide? All my channels are in the 70-80% do not fluctuate a lot.
This bug is driving my wife nuts. I hope they fix it soon.
Boot: 1013LADD
January 2004
None
Provided UHF remote
Don't think so.
No.
Yep, receiving Dallas locals. No other OTA stability issues.
Channel up/down on the OTA locals.
About every day. It's happened 3 times already this evening.
No.
"universal" remote for 522
Time to upgrade.
