Clearing Locals
bkushner
681
Audubon, NJ
Is there a way to delete all the locals? I know you can HIDE them but is there a way to wipe them all clean?
Brian
How about disconnecting the OTA antenna and then rescanning? Or will the receiver keep the channels it found in the old scans?
I tried this and it didn't work..Receiver kept the stations..
Brian
try disconnecting antenna and do a scan and it should wipe them all out
t
clean slate
after the rescan make sure that you press the green button to save 0 channels found, if you don't you will end up with the same channels you had before scan. Usual complaint is not finding enough locals. :shocked This IS a new one. :)
To SET 1080i in NATIVE RESOLUTION WITHOUT the SD Stretch...
Can I use 2 antennas?
