combine HD sat with comcast cable feed question
wease59
9
florida
I know in the old days of DTV you could combine dtv and OTA antenna through a sat. diplexor.I tried this with my new home setup with comcast cable and i could not get sat 99 at all.No signal.I remove the 2 diplxerors and conect direct and get signal at 99%
It was only 99 that would not come in .101 and all others were perfect?
Any ideas on hold to get this to work as the home was pre-wired.
Thanks for any help.
Actually there is a way,as long as you install the b-band converter before you diplex the satellite signal .
Actually attach the b-band converter to the
Diplexer that you are running from the dish
On the sat in port.
If you have an H/HR 23 or higher this will not work since the b-band in built into the ird.
multiple TV's on one receiver
"Classic" directv2pc and 'an error has occurred'
