Combine off air with Pansat?
janzy
SatelliteGuys Guru
126
I was wondering if a diplexor would work with a diseqc switch.
I have a 4 port switch feeding a pansat 9200 and would like to utilize my hidef off air antenna.
Do I put the diplexor after the switch or insert it before one of the ports?
This is how I have mine....
Pansat--------------->diplex----------------->other diplex---------------> diseqc----------------------->dish
I also did this once....
Pansat--------------->diseqc-----------------> diplex---------------> other diplex----------------------->22 khz----------->dish
and
Pansat--------------->22 khz-----------------> diplex---------------> other diplex----------------------->diseqc----------->dish
As long as the diplex are in order is should work. Putting a diseqc in the middle of them would not work and make little sense.
Diplexers will attenuate both satellite and terrestrial signals by 3dB (3dB is equal to the doubling of power). This attenuation often eliminates the weaker channels.
We advise installers not to use diplexers in FTA systems unless there are no other options.
2 FTA Receivers and 2 single ouput LNBFs
I sent an Email to Visionsat Tech Support
