Confirming info for hybrid LNB/node conversion
bxl4
SatelliteGuys Guru
125
Bainbridge Island, WA
I am in the process of upgrading the satellite TV watching to 4k capability. I'll own the equipment and do the installation myself. I want to do this in two steps but need to confirm that my plan will continue to work between step 1 and step 2:
Initial setup is old LNB gen on WA. One Hopper w/sling. One Joey 1.0.
Conversion step #1
Swap out the LNB for a Hybrid LNB. Install the Hybrid Solo Hub. Hook up the same Hopper and Joey.
Conversion step #2
Plug and play replace old Hopper and old Joey for Hopper 3 and Joey 4k.
Enjoy 4k TV.
Will everything still work after conversions step #1?
Thanks to all for the shared wisdom.
Conversion step #1
Conversion step #2
Enjoy 4k TV.
Yes, your current Hopper will continue to work on the Hybrid system. Just be sure to do a Switch Test also known as a Test Installation after you swap in the new LNB and hub.
Thank you! That was exactly what I was hoping for. This weekend is good for the LNB work but I don't want the Mrs to have to miss any of her shows were I to get 1/2 way into this and discover that I can't get reception until I have the Hopper 3.
Reactions: JSheridan
You're welcome. A happy wife is a happy life. :)
Hopper/Joey Remote Compatability
Trying to switch Hopper And Joey locations
