Connect all together
$225.00
ahaddad
8
Good evening
I have a DiSEqc 1.2 Motorized H-H motor,
I have DiSEqc Switch 4 in 1 out ( Chieta)
How can I connect them please, I got confused since I need to use the motor too
Any help will be appreciated
The motor works fine, moves from one satellite to another, using one L connection, now I want to use the C connector
Mo
place the switch betwen the lnb & the motor
i use L to 1 and C to 2 and then the one marked receiver to the motor (marked lnb) and then from motor to receiver
Thank you very much
And would you please tell me how should I do in my dish setting
Thank you very much for all your help
Mo
Circular outputs (C) have a local oscillator (L.O.) frequency of 11250, linear outputs (L) are 10750. Also, set your DiSEqC switch settings to look at the proper ports where you have each LNB connected.
Where to point dish when not in use?
Toroidal Setup
