Digiwave Diamond and Satellite capacity of 64 entries
regisma
58
Hi,
Can you confirm to me if the limit of the Digiwave Diamond is to support no more than 64 satellites?
thanks
Regis
Hi,
I have two LNB some satellites have a spectrum quite wide for FTA like the IntelSat 10-02 at 1.0W.
Someone explained me a trick so I can cover all the spectrum of it with two LNB.
The trick consist of create one satellite entry that handle the lower frequency and another one that is a clone of the first one but this second one will cover the higher frequencies. So if there is a limit it can be reached quite rapidely.
thanks
Regis
doesn't matter. even if you did configure each sat for ku high/low or C and Ku band, theres only around 10 sats or so up there with FTA (maybe a few more). So if you have 64 slots, thats only 20+.
Hi,
If I use the Al Satellite Alignment, it is a free software and enter my latitude and my longitude it generate me the following list: (see below)
thanks
Regis
N Satellite Position Azimuth Elevation
1 Telecom 2A 3,0°E 99.50 ° 0.51 °
99 AMC 8 139,0°W 251.75 ° 8.48 °
100 AMC 7 137,0°W 250.18 ° 9.84 °
101 AMC 10 135,0°W 248.58 ° 11.19 °
102 Galaxy 1R 133,0°W 246.96 ° 12.53 °
103 AMC 11 131,0°W 245.31 ° 13.86 °
104 Intelsat Americas 7 129,0°W 243.62 ° 15.17 °
105 Galaxy 13/Horizons 1 127,0°W 241.91 ° 16.47 °
106 Galaxy 5 125,0°W 240.16 ° 17.76 °
107 Galaxy 10R 123,0°W 238.37 ° 19.02 °
110 Anik E2 118,7°W 234.40 ° 21.67 °
111 SatMex 5 116,8°W 232.58 ° 22.81 °
112 Solidaridad 2 113,0°W 228.82 ° 25.00 °
113 Anik F2 111,1°W 226.87 ° 26.06 °
116 Anik F1 107,3°W 222.85 ° 28.08 °
117 AMC 2 105,0°W 220.32 ° 29.23 °
118 AMC 1 103,0°W 218.07 ° 30.19 °
120 AMC 4 101,0°W 215.76 ° 31.10 °
122 Galaxy 4R 99,0°W 213.41 ° 31.97 °
123 Intelsat Americas 5 97,0°W 210.99 ° 32.78 °
124 Galaxy 3C 95,0°W 208.53 ° 33.54 °
125 Intelsat Americas 6 93,0°W 206.02 ° 34.24 °
126 Brasilsat B4 92,0°W 204.74 ° 34.57 °
128 Galaxy 11 91,0°W 203.45 ° 34.88 °
129 AMC 3 87,0°W 198.20 ° 35.97 °
130 AMC 9 85,0°W 195.51 ° 36.42 °
131 Brasilsat B3 84,0°W 194.15 ° 36.62 °
133 AMC 5 79,0°W 187.27 ° 37.34 °
134 SBS 6 74,0°W 180.28 ° 37.59 °
136 AMC 6 72,0°W 177.48 ° 37.56 °
137 Nahuel 1 71,8°W 177.20 ° 37.55 °
138 Brasilsat B1 70,0°W 174.68 ° 37.45 °
139 Brasilsat B2 65,0°W 167.76 ° 36.87 °
140 Estrela do Sul 1 63,0°W 165.04 ° 36.50 °
141 Rainbow 1 61,5°W 163.01 ° 36.18 °
143 Amazonas 61,0°W 162.34 ° 36.07 °
144 PAS 9 58,0°W 158.37 ° 35.29 °
145 Intelsat 805 55,5°W 155.14 ° 34.54 °
146 Intelsat 707 53,0°W 151.97 ° 33.68 °
147 Intelsat 705 50,0°W 148.28 ° 32.54 °
148 PAS 1R 45,0°W 142.39 ° 30.38 °
149 PAS 3R 43,1°W 140.24 ° 29.48 °
150 PAS 6B 43,0°W 140.13 ° 29.43 °
151 NSS 806 40,5°W 137.37 ° 28.18 °
152 Telstar 11 37,5°W 134.17 ° 26.60 °
153 Satcom C1 37,5°W 134.17 ° 26.60 °
154 Intelsat 903 34,5°W 131.08 ° 24.95 °
155 Intelsat 801 31,5°W 128.11 ° 23.22 °
156 Hispasat 1C, 1D 30,0°W 126.65 ° 22.33 °
157 Intelsat 907 27,5°W 124.29 ° 20.82 °
158 Intelsat 905 24,5°W 121.54 ° 18.96 °
159 NSS 7 22,0°W 119.32 ° 17.38 °
160 Intelsat 901 18,0°W 115.87 ° 14.78 °
161 Telstar 12 15,0°W 113.37 ° 12.80 °
162 Gorizont 32 14,0°W 112.55 ° 12.13 °
163 Atlantic Bird 1 12,5°W 111.34 ° 11.13 °
164 Express 3A 11,0°W 110.14 ° 10.11 °
165 Atlantic Bird 2 8,0°W 107.78 ° 8.08 °
166 Telecom 2D 8,0°W 107.78 ° 8.08 °
167 Nilesat 101, 102 7,0°W 107.01 ° 7.40 °
168 Atlantic Bird 3 5,0°W 105.47 ° 6.03 °
169 Amos 1, 2 4,0°W 104.71 ° 5.34 °
170 Intelsat 10-02 1,0°W 102.46 ° 3.27 °
171 Thor 2, 3 0,8°W 102.31 ° 3.13 °
I just checked and east of Echo 3 (61.5), the only ones that have KU band to the US are
PAS9-58
T11-37.5
Hispasats-30
T12-15
everything else is either C-Band or not aimed at US/Canada
Hi,
I just check and My tree hide 90 degree West up to 140 Degree West!
So if I'm right I do not miss much, I hope.
thanks
Regis
Sathawk 3000 whats so good about it, and how will this help me
Help hooking up my sg2100 motor
