DirecTV only getting odd numbered transponders
gedmfc
Hello,
I just got a used oval satellite dish with two LNB's (one for sat at 101 and the other for 119) from a tenant that left it behind before they moved from my apartment. I'm trying to install it at my home right now. I have two Sony SAT-B50 Receivers. It seems like this receiver only supports one satellite, is that right? when I go to the installation menu, it does not have an option for an oval antenna installation.
anyways, I tried to find the satellite and could not find it. I have a very clear view to the SW, (Im located in Fort Lauderdale, FL).
so what i did is take out the integrated multiswitch and connect the receiver directly to one LNB. Now I was able to find a satellite (I think is the 101) however Im only able to receive signals from odd numbered transponders 1,3,5,7 etc, up to 31. but when I switch to even numbered transponders I do not get a signal at all.
I bought a signal amplifier and that did not solve the problem. I used the second LNB to test if it was the LNB causing the problem, But it was not.
I checked the voltage coming out of the cable and I get 14.3 V for odd transponders and 18.4 for even transponders, so it seems like the receiver its supplying the right voltage. what could be wrong?
do you think it is the multiswitch that I took out, maybe the LNB's works only with the multiswitch.
any hints guys?
I don't think SAT-B50 support oval dish with 2 LNBs. SAT-B55 will.
Why don't you call DirecTV and ask them.
Welcome to Satelliteguys!! :welcome
Do you have any splitters in your cable? If you do you will get this same problem.
Sounds to me as if there is some sort of cabling problem. Apparently the cable is working well enough to send the 13v but not the 18v. If you are using a flat cable to come through a window or door this could be the culprit. It could also be the use of RG-59, a splitter, crappy fittings, compressed cable(by a staple or sharp bend) etc etc etc... GOOD LUCK
You should be able to get one satellite without the multiswitch.No even transponders usually means a short in the wire somewhere.
The Sony B50 receivers have a destacker built in for wideband (commercial standard) signals.
If the receiver is set up in wideband mode, sometimes you will get only odd number transponders and the even numbered will be 0 signal if you are on a normal satellite connection using a standard signal.
To switch this, go up to the receiver itself and press the Down and the Menu button at the same time. This will bring up a hidden menu. Highlight and select the "Tuner" option then select the Standard option.
If you have some kind of setup using a stacker and the signal needs to be 'destacked', do the same thing except select the 'Wideband' option. The signal MHZ is usually 575 however you will know if this is right or not if the channels are coming in on the wrong number (mtv on channel 202, cartoon network on 255, etc).
Good luck.
(edit: fixed typos)
Audio/Video Not insync on FOX 88 HD
samsung 360 or RCA 210
