Last week 671-3 was repurposed for a potential NBA feed if Diamond defaults on their payments during the season.
Yes, I can watch it OTA. Yeah, it's 720P, but it sure doesn't look it. The DirecTV mpeg4 feed of that signal is just as good.Do you have an antenna at your NC home, if so, does it pick up WNCT? They carry CW on their D2 sub-channel in HD.
Guess they won't have to worry about this in Detroit:Remaps of CW Plus were added to channel 60 in Butte, Great Falls and Missoula as they no longer have an OTA affiliate. (Depending on what happens with WADL, it might be added to Detroit too in the next few weeks)
www.nexttv.com
I re-enabled my LCC, and comparing the OTA signal to the DirecTV feed of CW on my local WNCT-D2 channel, the OTA signal is 720P and the satellite feed is lower resolution, so the SD label in the Guide is correct. With the LCC enabled, I can record the ACC basketball games on The CW if I need to. Problem solved. I just have to remember to disconnect the LCC from the antenna and rescan before we move north next spring, Otherwise I keep seeing the North Carolina OTA channels in my guide, when the LCC is in North Carolina (It's worthless in the Adirondacks, no OTA available.)Do you have an antenna at your NC home, if so, does it pick up WNCT? They carry CW on their D2 sub-channel in HD.
LIVE Streams | National | Spot Beams | ||
Count | Change | Count | Change | |
4K | 3 | -1 | | |
HD | 275 | | 1447 | |
SD mpeg4 | 140 | | 197 | |
SD mpeg2 | 403 | 1 | 440 | |
RB | | | | |
Audio | 89 | | | |
Push | 31 | | | |
Slate | 21 | | 1 | |
TEST Streams | National | Spot Beams | ||
4K | | | | |
HD | | | | |
SD mpeg4 | | | | |
SD mpeg2 | 4 | 4 | | |
RB | | | | |
Engr Work | 54 | -3 | 2 | |
while the one with the typo is not yet fixed, they did copy and paste the labels/notes into 9521-9525The extra ESPN+ for Business channels have been added (one of which is incorrectly labeled "EPSN+")
They probably must be grayed out, one of my bar's boxes is a big old H23 and the grayed out channels are not there on that guideNoticed PrimeTNF 9526 and 9550 are gone, looks like they are now "isolated" to business customers guides.
Then the Sunday ticket channels on your guide should also be goneNope. I don't have CIG enabled and they still aren't there.
