DIRECTV Transponder Map ~ Data 11/25/2026
KEDZ/27 is now live in the Fresno DMA
College Football Mix is back
425 BabyTV was removed after the shutdown of its US and Canadian feeds earlier this month
CINE 176 is being repurposed for the Sunday Ticket Auth slide on 9567
CW Island Network is testing on channel 186 for Puerto Rico (a pay TV only feed that is run by WSEE's owner Lilly Broadcasting, who also handles CBS, FOX and Cozi for much of the Caribbean)
DirecTV Satellite Transponder Updates for Aug 26 2026
Comparison of Transponder Data for Aug 26 2026 vs Aug 19 2026:
No changes in system tables for any transponder tuning parameters.
Changes to the use of defined transponders:
2 Transponders cleared of all Streams::
Net 10 TID 135 Beam NAT is a National Transponder on D11@99cb, TPN 12
Net 15 TID 124 Beam NAT is a National Transponder on D15@103cb, TPN 1
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
272​
1446​
-1​
SD mpeg4​
143​
1​
193​
SD mpeg2​
439​
-1​
RB​
Audio​
89​
Push​
26​
Slate​
19​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4​
1​
SD mpeg2​
RB​
Engr Work​
27​
-15​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
Weekly Analysis soon
Enjoy
DataDigestsers
Some Center Ice and League Pass prep
9547 "Netflix Commercial MLB" was renamed to "Netflix Commercial"
WRTV Indy is repurposing Dispute Slide 1 Test 9109 for the Circle City dispute
Some more TPN swaps
Someone screwed up and incorrectly mapped CW Island Network to the schedule for WPIX
Oklahoma City Thunder - TBA, rumored to be seeking an OTA deal
KSBI/52 Oklahoma City, not yet available for streaming customers
KQCW/19 Tulsa
Their FAQ page says there will be a feed on channel 675 for Kansas, Arkansas, Missouri and Nebraska
Reactions: Nate.O’Brien
From this article and post from OKC Thunder Threads account The OKC Thunder they have partnership with Oklahoma's local brodcast company Griffin Media and will be on KSBI (channel 52 My Network Television) in OKC & in Tulsa KQCW (CW channel 19). The team has a streaming opinion too called Thunder+ were non National games will be Broadcasted. a dedicated channel on 675 on Directv sat/stream.
Stars -> Victory+ with simulcasts on KDFI
The Stars are now rumored to be leaving Victory+ for Prime Video, hopefully this also means a channel will be coming similar to what they have for the Kraken who stream locally on Prime.
The Minnesota Lynx will likely need to find a new home next season too.
Is there any channel info on the St. Louis ABC local that switches from Sinclair to Gray Media tomorrow? Like what channel will it be on tomorrow on DIRECTV?
For what it is worth...not much, Google AI says this about it:
"Even though the over-the-air broadcast is shifting from Sinclair's KDNL to Gray Media's KMOV digital subchannel (over-the-air channel 32.1 / 4.2), major satellite and cable providers retain the traditional, familiar major network channel slotting for their local guides."
That AI response is full of errors. 4.2 is still going to be KMOV's Weather channel. ABC is going to be on 32.1 via KMOV's RF 24 signal and 32.10 via KDTL-LD's RF 17 signal. Matrix Midwest/MyNet moved to 32.2 in SD via KMOV's signal and 32.3 in HD via KDTL-LD's signal and is keeping its channel 6 position on Spectrum. No cable or sat positions for ABC have officially been announced.
KDNL is going independent and keeping all of its existing syndicated programming, including Live with Kelly & Mark and Tamron Hall
KMOV released this info today. The article below states "DIRECTV & AT&T U-verse: Channel designations are currently TBD" however as mentioned previously it is on Channel 30 this morning. And whatever KDNL is broadcasting now is not on my DIRECTV receiver anywhere.
What you need to know about First Alert 4 on ABC
App channels disappearing and reappearing
