DIRECTV Transponder Map ~ Data 11/25/2026
It's only available for streaming customers, they still haven't added that batch of CW stations to satellite.
Even if it was, satellite customers still can't stream their CW affiliates via the app, just the Big 4, select PBS stations and some independents (mainly the ones that have full season NHL/NBA rights)
Reactions: dtv757 and Mr Tony
WCWW/25 CW South Bend and WBKP/5 CW Marquette are now testing on the stream server. These are both already available on satellite.
Now live in the satellite guide:
663-2 PISTONS (663-1 is likely being reserved for an overflow feed of Detroit Sportsnet, if there's a 2027 MLB season)
675 THUNDER
693 CLIPPERS
Reactions: Mr Tony
DirecTV Satellite Transponder Updates for Oct 21 2026
Comparison of Transponder Data for Oct 21 2026 vs Oct 14 2026:
No changes in system tables for any transponder tuning parameters.
Changes to the use of defined transponders:
1 Transponder cleared of all Streams::
Net 10 TID 126 Beam NAT is a National Transponder on D11@99cb, TPN 3
1 Previously unused Transponder with current APG records::
Net 15 TID 15 Beam NAT is a National Transponder on D12@103ca, TPN 16
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
264​
2​
1449​
SD mpeg4​
145​
194​
SD mpeg2​
433​
RB​
Audio​
89​
Push​
26​
Slate​
19​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4​
SD mpeg2​
RB​
Engr Work​
38​
-2​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
NBA Updates
Weekly Analysis soon
Enjoy
DataDigesters
HAWKS, HORNETS, GRZZLIES, HEAT, MAGIC, CAVLIERS, TWOLVES, BUCKS, PACERS and SPURS channels have also been added, however they are pointing to a TV Promise slate, which says they are working with DAZN and others to strike a deal for those teams.
Some more TPN swaps
Some more TPN swaps
Wait…..
So even though DAZN keeps touting 'only way to see games' if you are a subscriber to Choice (like my stepdad) if an agreement is reached he can see the Wolfies on 668?
I know the Wild are in dispute and a slate is on 668-1.
675 THUNDER
693 CLIPPERS
They're finally live in the app's API, doing a check
PISTONS is not available in Detroit (WMYD/20), it is available in the rest of Michigan including Marquette who also gets the games on their MyNet station WJMN/3, along with the Toledo DMA and the northern portions of the South Bend and Fort Wayne DMAs.
THUNDER is available in OKC and Tulsa, so I wonder if DTV is just going to keep the OTA feeds of KSBI/52 and KQCW/19 and direct viewers to 675 for the rest of the games.
On stream it's in Choice for Oklahoma (inlcuding the Oklahoma portions of the Amarillo, Sherman-Ada, Wichita Falls-Lawton and Joplin DMAs) and Western Arkansas and requires Sports Pack for Nebraska, Kansas and Western Missouri, I'm not sure if it's the same for satellite.
Some more TPN swaps
It appears we are not getting both home & away feeds out of market on League Pass for these teams either…
I've been watching the Spurs home feed on channel 676-1 (was part time San Antonio specific feed) out of market with NBALP for YEARS on satellite (through the multiple iterations of Fox Sports SW, Bally Sports SW, FanDuel Sports SW) Looks like that will not happen unless a deal is reached with DAZN. I do see the placeholder channel on 680 if it happens.
Reactions: Nate.O’Brien
Center Ice does have the non-carried feeds, including the Hurricanes, Wild, Blues and Blue Jackets and spotbeam local only teams like the Panthers, Mammoth and Golden Knights. So it probably depends on the available part time bandwidth each night as things they are able to provide to in market viewers in the 600s, PPV Events in the 100s and commercial events in the 9000s get priority first, along with games where neither team has a remappable feed.
League Pass tonight for example (it is almost a full slate tonight):
Hawks @ Magic (only Hawks feed which is easy to insert since its OTA this season and simulcast across multiple Gray Television markets, Magic signed a non- exclusive streaming deal with DAZN and also OTA)
Bucks @ Wizards (only Wizards feed easy to remap, Bucks are OTA & there own streaming service Bucks+)
Hornets @ Nets (only Nets feed which DirecTV already carries so simply YES remap, Hornets signed non-exclusive streaming deal with DAZN, also OTA)
Bulls @ Raptors (Bulls only feed via CHSN remap, its common that we don't get Raptors feeds that often)
Jazz @ Grizzlies (Jazz only feed OTA easy to insert, Grizzlies signed streaming deal with DAZN)
Pacers @ Pelicans (Pelicans only feed which is OTA easy to insert, Pacers signed streaming deal with DAZN)
Maybe it will change but it looks like DirecTV may only carry DAZN feeds on NBA LP when there is no other option, such as when two teams (either Cavaliers, Pacers, Grizzlies, Timberwolves, Spurs) that are both DAZN exclusive are playing each other, we shall see as the season goes on I guess.
This NBA season will be the first in a long time where many League Pass games are carried on feeds DirecTV doesn't normally carry or are only available through OTA spot beams. It'll be interesting to see how it plays out, especially whether we eventually get both home and away feeds for these teams out of market again.
Reactions: Mr Tony
Now in the Hornets and Hurricanes markets we just get the TV promise screen. But Directv still charges sports fee I am assuming.
Luckily my DTV stream package doesn't have a rsn fee. Figure DTV that always says is the leader in sports would have come to an agreement by now.
Reactions: Mr Tony
Greenville-New Bern is $11.99 for MASN (Orioles) and Nationals
Raleigh is $11.99 for MASN and Nationals
Charlotte is $12.99 for BravesVision, MASN, Nationals and Reds
The fee in NC also includes the higher in state rate they have to pay for ACCN. Down in SC the fee is $15.99 as they are also a SEC state.
I'm not sure if they're doing it with those teams, but in some markets they also use the fee to cover the additional cost they have to pay for independents and MyNet stations that picked up full season NHL and NBA rights.
If you go to the TVPromise site, you'll likely be able to get a credit for not getting the Hurricanes and additional Hornets games that air on WITN-D2
Part of the hold out might be the packaging and price for outer areas like how the Thunder needs sports pack for other states. Hopefully they are also pushing for a guarantee from the teams that they would require whoever wins their local broadcasting rights in 2028 to negotiate with MVPDs. Commercial distribution rights are probably a factor too.
I'm guessing they got a deep discount for the Clippers based on how long it took them to officially announce ClipperVision and their KTLA simulcasts after they were basically handed a multi-year draft death penalty.
The Predators and Pistons channels are using feeds supplied by Scripps Sports
The Heat likely depends on whoever they sign for the Fort Myers DMA, as there's no point in paying a high price for the Heat just for that DMA when WPLG is streaming it for free on their app and website for viewers in the Miami DMA, and they already carry the West Palm Beach station.
Reactions: Mr Tony
I tried this with both the Hurricanes and Hornets since I'm in upstate SC, and wasn't offered any kind of credit by the site. It's not a huge deal to me as I can pick up WSOC/WAXN over the air at my location even though I'm outside the Charlotte market.
I thought the NBA TV contracts were short term as the NBA is trying to get all of the teams into in an all in one streaming app?
649 GRZLLIES and 671 PACERS are now available.
660 CAVLIERS, 668 TWOLVES and 680 SPURS are now available
One thing these five teams have in common is that they all signed exclusive local streaming rights deals with DAZN, replacing their traditional regional sports networks.
I know the Spurs will have 22 games available OTA on KMYS-TV CW35 in the San Antonio market, but they'll still be available on DAZN as well. The CW35 broadcasts are an additional option, not an exclusive arrangement.
With channel 680 now available, we should be able to get all the Spurs home feeds on NBALP again! (as well as the other teams above of course)
Reactions: Mr Tony
App channels disappearing and reappearing
