Hi Everyone,
I have been frustrated with DiSEqC switches since I first started this hobby about a year ago. I had a 90cm dish with a HH100 motor and a circular and linear LNB on it. With one coax running to the dish, I wanted to have the ability to select either the circular or the linear LNB, so I used the 4-port DiSEqC switch that came with my Fortec receiver. From what I read here, it should be hooked up between the motor and the LNB's, which implied that it had to go outside. I hooked it up, and never got it to switch properly. Sometimes it would switch, and sometimes it wouldn't. Usually turning off LNB power in the Fortec setup and turning it back on would force a switch, but 9 out of 10 times changing channels/satellites would not.
I tried a few more DiSEqC switches and none of them would work reliably (tried a Spaun 4-port, Sadoun 2-port and Pansat 4-port). All of them exhibited unreliable switching behavior... I ended up blaming it either on the Fortec receiver, 100 ft cable run to the dish, or the motor inbetween the receiver and the switch, or the fact that the switch was outside. Basically, I gave up..
Now.. 6 months later, I have a second 90cm fixed dish and a dish-500 dish as well with dual legacy LNB's and I would like to switch between the Invacom LNB (linear) on the 90cm fixed dish and the two LNB's on the Dish-500 dish. I spent the time and effort to pull individual coax (Quad shield) wires from the dishes into the house (and put in a few extra runs, you never know!). So now I can have the DiSEqC switch closer to the receiver and inside, and no motors inbetween... And since I first started the hobby, I also have two more receivers. A Pansat 3500 and a Twinhan 102g PCI card. So I figured this should work... YEAH RIGHT!
What's happening now, regardless of the receiver or switch I use, it seems fine switching to the first LNB (the linear one) on the switch. That seems to be 100% reliable, but switching to the second or third (or fourth, I tried that port too) just isn't reliable. Sometimes it will switch there, but after a few seconds it switches back to LNB1. Other times nothing seems to happen..
What is going on???? Do I have the bad luck of having 4 bad DiSEqC switches and/or 3 bad receivers?? And yes, I did ALWAYS power down before messing with the DiSEqC switches.
I run MyTheatre on the PC with the PCI card and had it tuned to a channel on IA5 (BVN TV) which was using the first (Invacom) LNB on the switch. Then I went into the MyTheatre LNB/channel settings menu and clicked on the DiSEqC button (which brings up the DiSEqC menu). I chose LNB2 and clicked on "Do NOW". I see a brief interruption of the video/audio on the channel, but it goes right back. No matter whether I choose committed or non-committed, first or second switch... Can anyone who has MyTheatre and a switch try this for me? Does anyone know anything about the advanced DiSEqC setup parameters in MyTheatre? Could they help in any way?
Hope anyone can shed some light on this issue! At this point I just can't believe anyone out there has a switch that actually switches reliably..
Thanks,
Robbert
PS.
Sorry for the length of the post... Just wanted to let you guys know all the facts...
Thanks,
Robbert
PS.
