Dish 1000 install
tomdkat
92
I am replacing my 500 with a 1000. My current set up is a 119/110/61.5. I am going to go to 119/110/61.5/ 129. When I install can I keep the same mast? also when I connect to my DPP44 do I just take the 129 feed and run it to the switch or should I do that lnb loop that it shows in the diagram
Yes, you can use the same mast. Just had a 1000 installed to replace my 500 last week. Not sure on the other stuff
The best way would be to keep the 61.5 and replace the 110/119 with a D1000. The LNB's are up to you. I would recommend using a DP Twin and DP Dual on the 1000 and run all 4 locations (110, 119, 129, 61.5) to your DPP 44 switch.
As long as you run the 119 into port 1 on your switch, you should be fine.
superdish or dish 1000
feed 942 input (antenna) from dvd rf ch3 output
