Dish 1000 vs 1000.2 signal strength
Jerryinvirginia
556
The biggest improvement between these two is the 1000.2 is easier to align. The 1000 is much more particular on getting a sutible 129 level. The triple lnb on the 1000.2 has greater receiver capacity..........a winner, overall.
FitzAusTex
1,127
Austin, TX
Probably not many of you out there, but has anyone replaced a 1000+ with a 1000.2? The 1000+ is a bit bigger, but there are 3 separate LNB housings for the 4 sats, and I'm wondering if I might get a better signal with the triple LNB on the 1000.2, even though the dish is smaller. (btw, I dont subscribe to anything on 118.7 anymore, so dont need that sat anymore).
Jerryinvirginia
556
If damage occurs to the 1000+ you probably could sub the 1000.2. Otherwise, keep what you have..."don't fix what ain't broke"............
Smith P.
On Vacation
Oct 4, 2003
8,907
Bay Area, CA
Not sure - if you can measure distances between center of each LNBF, plus a distance between middle LNBF and center of the dish.
I can do same for D1k2. It could be different then it will affect SS, especially for side LNBFs - 110 and 129.
Bradtothebone
785
6
KC Area
I have a 1000, is it possible to retrofit it with the 1000.2 lnbf using the same reflector? The LNBF is cheaper on ebay.
Not sure if you'd get all the advantage by just changing the LNBF's. The 1000.2 reflector is bigger (about 1.5") in each direction, also.
Brad
FCom911
287
What differentiates 1000 from the 1000.2?
Mine is a 1000, but has 1 Dual Head LNB, and a Single Head LNB.
Or is the parabolic antenna a better shape, design (more efficient) w/the 1000.2?
Or does it simply refer to a Single 3 Head LNB vs 2+1 Head LNBs?
Or is it all of the above?
FCom911
287
Thank you...
I've been experiencing fairly inconsistent issues w/129.
I had an appointment set for Monday, but after reading posts regarding 129 issues, I called Dish again and reiterated the necessity for me to take the day off for service, and to please make sure the installer has all the correct assets at their disposal to make it a 1 day event.
So in calling Dish, I asked the CSR supervisor to make sure the installer brings a new 1000.2 antenna and LNB. She said she modified the order for the appointment on Monday, 0800-1200.
I hope this will help w/my 129 issues.
Possible to watch recordings from multiple DVRs?
Losing the signal very easily
