DISH LNB or LNBF?
Zephyr Triple Crown
16
6
FL, NY, KY
I moved my H3 from the Coach to the Park Model and the signal is weak. On the Coach I had the Winegard Trav'ler. At the Park Model I got a fixed dish setup from Solid Signal. DISH Network Triple LNB HD Western Arc (VOOM) Dish Antenna(DISH1000.2). Just couldn't get it to pickup a signal. Took the LNB from the Coach and I got a signal that gave me service but the slightest foul weather it was out. Apparently the LNB from Solid Signal was a Reman piece. I complained and they refunded me. So now I'm thinking that my Coach LNB is getting weak and I should get a new one. From what I've read here that any that you get for DISH is Reman even if it says that it's new it's a Reman? How do I tell if my LNB is 100%? And what I'm buying is good too. Do the LNB's fail because of sun damage to the white horns on them? The two triple LNBs I see are the 145511 and the 151027 Hybrid? (I think I have this one). My system consists of the above dish and LNB, a DPH42 Switch and a power inserter and a splitter node then to the H3 receiver. Thoughts? Thanks
Get rid of the triple, the 42 switch, and the power inserter, and see if you can get a Dish 500 kit with a Western Arc Hybrid Twin LNBF. That is compatible with ALL receivers now and is what is used on all installations (Western Arc)
A couple of the things you asked didn't really get answered yet, so here's what I'd check before buying another LNB.
First, how to tell if an LNB is actually going bad: don't go by one signal number. Go into Point Dish and check signal strength on 119, 110 and 129, scrolling through a few transponders on each. A healthy LNB is fairly even across transponders on the same satellite; a dying one usually shows some transponders much lower than the rest, or readings that drift down as it warms up in the sun. Run the same check cold in the morning and again after it's been in the sun, and run Check Switch — if the switch test starts failing or losing a satellite intermittently, that's the LNB or the cabling, not the receiver.
On the 'new vs reman' question: a lot of the LNBs sold as new are in fact remanufactured — look for a reman sticker, a date code, or a feedhorn that looks scuffed or sun-faded rather than clean white. A reman isn't automatically bad, but I wouldn't pay new money for one without checking that, and I'd test it the way above rather than trusting the label.
And yes, the sun does kill them. The white feedhorn caps get brittle and crack after years in the sun, moisture gets in, and the LNB starts drifting or dropping out in rain first — which matches your 'slight foul weather loses signal' symptom. Look closely at the cap and the throat of the feedhorn for cracks or green corrosion, and check the coax connector at the LNB for water as well.
On your two triples: 151027 is the Hybrid triple, which is the one you want with a Hopper 3, and 145511 is the older DPP triple — that one is why you need the DPH42 and the power inserter in the chain. HipKat's suggestion to simplify to a Hybrid setup removes two failure points, and I'd agree with that if you're replacing parts anyway, but I'd do the signal checks first so you know whether it's the LNB, the switch, or just the feedhorn cap before you spend on anything.
all of the harware is a reman. with maybe the new dish 500 WA twin LNB
There is no 129, and because of that, as I said, the triples are obsolete, and all Western Arc dishes for all receivers, not just hoppers, use the DPH twin Western Arc.
The WA twin is like a SWM setup one coax from the LNB to a solo hub and the joeys are connected to the hub i think if you want more than two joey's splitters are hooked up to the hub aswell then each joey is ran off a splitter.
When I bought the reman 151027 Signal Group knew that I was running the DHP42 with the power inserter. From what you said I don't need the switch ? So combining them is an issue?
for a hopper 3 and a joey you just need the wa twin dish a the hub not the node. one coax from the lnb to the hub then the hub feeds the hopper and joey or joey's. if you want more than two joeys then you'll need slpitters.
As I am still learning, this is what Google Search AI says:
Based on the technical specs of the DISH distribution architecture and the thread you shared, HipKat and slow_poke_pete have the correct answer.
The user 4KMediaTV posted outdated advice by telling the thread starter to check satellite 129. DISH officially retired the 129° orbital slot for Western Arc HD programming. Because of this, using an old Triple LNB (which targets 110°, 119°, and 129°) with an external DPH42 switch is completely obsolete for this setup.
As HipKat pointed out, the right solution is to strip out the Triple LNB, the external DPH42 switch, and the power inserter entirely. The optimal modern setup is a standard Western Arc Hybrid Twin LNBF linked to a DPH Hub.
The Absolute Difference Between a Hub and a Node
The primary difference between a Hub and a Node in the DISH ecosystem comes down to the generation of technology they use: DPH (Dish Pro Hybrid) versus DPP (Dish Pro Plus).
1. The DISH Node (Legacy DPP Technology)
  • The Technology: Nodes use legacy Dish Pro Plus (DPP) data stacking protocols.
  • How it Works: A Node takes standard RF satellite lines coming down from an older, non-hybrid LNB (like a DPP Triple 145511) or a DPH42 switch. It dynamically stacks the frequencies so that multiple tuners can share a cable run.
  • Wiring Limits: It requires a separate power inserter in the line, utilizes older analog translation layers, and has a much bulkier footprint inside an equipment chassis.
2. The DISH Hub (Modern DPH Technology)
  • The Technology: Hubs use modern Dish Pro Hybrid (DPH) digital Channel Stacking Switch (CSS) technology.
  • How it Works: A DPH Hub functions strictly as a high-frequency, single-cable digital routing terminal. When paired with a native Western Arc Hybrid Twin LNB, the LNB handles all the multi-satellite switching internally right at the dish reflector.
  • Wiring Advantages: You run one single coax line directly from the Hybrid LNB straight into the DPH Hub's input. The Hub then instantly breaks that single digital pipeline out into a dedicated client matrix line for your Hopper 3 and independent distribution lines for your Joeys. It does not require an external switch or a separate power inserter—making the entire footprint incredibly clean, efficient, and weatherproof.
What about folks that have two Hopper 3s? Will the new Wesrern Arc dish handle that?
Updated to H715 on a Hopper 3 from H713
Dish now OUT of Bankruptcy - Business as Usual
