Dish point
I'm to far away to stop by but you should be able to do this yourself.
1) Make sure the mounting pole is plumb
2) Set the elevation on the dish to 44 degrees
3) Set the skew angle on the dish to 123 degrees
4) Slowly rotate the dish around the 218 degree azimuth angle until you get a good signal on the dish point screen and then lock it down. (When pointing the dish you're not pointing the dish face to the azimuth angle but rather you point it in a line parallel to the elevation angle brackets on the back of the dish.)
Grainy/blurred HD picture - vip 211
Dishpro twin lnb for wing dish
