Dishnet 322 receiver
buyme2
If I replace my 301 with 322, will I now be able to get 2 signals from the single feed or will I have to have Dishnet to activate it?
A 322 requires two inputs from the satellite dish to work. Officially it is only available to new Digital Home Plan customers.
A special splitter will be able to split one line into two in which should be coming later this year.
I have Dishnetwork 322 receiver
322 Receiver needs software modification, to eliminate incompatibility issues with non Echostar DVR units!
Screen Saver with Dish network Logo and Text (Push Select to Continue) pops up and gets recorded by my ReplayTV 5040 after daily Dish Network Software update and or every 4 hours if no remote control button is pushed. This Logo stays on screen and renders my ReplayTV 5040 TOTALLY USELESS.
EXTREEMLY ANOYING and TOTALLY UNEXCEPTABLE
I never had these ridiculous problems with my ReplayTV 5040 and Cable Company!
After more than 7 days and several calls to Dish Network Tech support, I may or may not have workable solution.
Whether this solution works or not it is very poor workaround at best.
I currently have 8 reminder timers (1 every 3 hours) set to simulate remote control activity, in order to keep the 4 hour inactivity screen saver from activating. Due to software updating Daily at 4:00 AM I had to set additional timer at 4:10 AM to keep from having screen saver started after software update.
SUGESTION PLEASE EXPEDITE SOFTWARE MODIFICATION ON 322 RECEIVERS TO INCLUDE CHECK BOX.
[ ] DISABLE SCREEN SAVER
This would be much preferred to my current workaround that may or may not work
ATTENTION THOSE WITH ANY TYPE RECORDING DEVICE being used with DISHNETWORK 322 receiver!
This work around works best!
Menu 616 takes you to Updates Screen then chose Activation Disable!
That's it no more bouncy ball (Press Select to Continue) Dishnetwork Screen Saver.
Warning this workaround may cause other less serious but extremely aggravating problems due to Dishnetworks poorly written software!
322 Receiver incompatible with non Echostar DVR units due to poorly written software!
Duel Tuner - 322
New software revs for 322, 522 and 111
