Sorry wrong forum. Can admn. delete this post?
Hi Kind Folks:
I need help installing a dishnetwork dish 500 with two LNBFs. I started yesterday with cable hooked to 119 LNBF, and when I was adjusting I was able to get both Satellite 119 and 110. However I could not get 61.5W (guess I have bad line of sight)
Here is my info!
Zip Code 48331, from www.dishnetwork.com Azimuth = 228, Elevation = 31, Skew = 119.
My need is to get International-South Asian programming and it comes on following satellites Satellite 148, 0r 121, or 61.5.
I have following questions and need your help desperately.
1. Can I point to either 148W or 61.5W, since according to www.dishnetwork.com "We are not able to offer international channels on the 119 or 110 satellite locations due to the space contraints on the satellites in those orbital slots. All international programming (other than the DISH Latino programming) is only available on the 61.5 or 148 satellite locations."
2. For Echostar 61.5W, Azimuth is 149.6 and Elevation is 36.4
3. For Echostar 148W, Azimuth is 252.5 and Elevation is 9.6
4. Which LNBF I shall connect to (I was connected to 119 when I got satellite)
5. How much is correction of Azimuth at my location
6. Is this correct 110W is left of 119W and 148W is right of 110W. I think I have a bad line of sight for 61.5W from my back balcony (2nd floor). However, for 148W, the elevation is very low. Does this make a difference for signal strength?
7. I know where approx. North is at my location, for calculating azimuth, which website should I use this www.satsig.net/ssazelm.htm or www.csgnetwork.com/antennasatelazposcalc.html. In the first website 148W is calulcated by inputting -148? is this correct?
8. Please correct me if I am wrong, the Azimuth is calculated starting north going clockwise?
Thanks for replying and please pardon me for long list of questions, I spent 6 hours yesterday (one guy moving dish and then walking in and out to see signal). I do have the satellite signal finder, borrowed from friend, but no compass.
			Hi Kind Folks:
Here is my info!
 , DishNetwork says u need more than 70 for good pircture. I tried to fine tune but 65 is max I get.
