Does 811 require Dishpro LNB?
G
Guest
Guest
I have a dish 500 setup (non Dishpro). Will this work?
I ask because I was looking at the spec sheet here and saw the DISHPRO logo next to the SAT IN connector.
Thanks.
John Corn
The Coach / Supporter
1,237
19
North Canton, Ohio.
No, but you will have to buy a DishPro adapter. I think there around $65-75.
http://www.dishstore.net/product_info.php?cPath=23_25&products_id=86
sinnfein07
Nov 13, 2003
27
New York City
I am confused - I thought the Legacy adapter was to use Dishpro switches with Legacy receivers, not the other way around. I was under the impression that the 811 will work just fine with legacy LNBFs.
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
104,128
30,705
Newington, CT
No it does not have to be a Dishpro LNB and you do not need an adapter eaither. :)
(You need an adapter if you have a older legacy receiver with newer Dishpro LNB's) :)
additional hardware needed for 811?
G
DP34 switch and signal strength?
