DP34 for 77,110,119
tetercreekcouple
Apr 2, 2009
15
WV 26250
Can I use a DP 34 to combine the signals from a dish 500 and a single dish set up for 77? Distance is too great to run the 77 dish to the 500. However both are close enough to my receiver if I can use the DP 34. Will it work? I have a VIP 211K receiver.
Mr Tony
2,092
8,491
Mankato, MN
you can use a DP34 switch (or a DPP44+ or DPP33) to run any of Dish's orbial slots through it.
But can I ask why 77? If you have Clarksburg, WV loclas they are on 129W (I guess you are a "mover" ;)
tetercreekcouple
Apr 2, 2009
15
WV 26250
Nope not after HD. Just some locals. My 77 dish setup works great. Good signal and the locals are there that I was looking for. I just wasn't sure about the switch. Scubasteve said to use a DP and not a DPP. Is that what I need to do?
tetercreekcouple
Apr 2, 2009
15
WV 26250
Iceberg, I don't know much as you can probably tell. If I change to a DP twin, will I need to run two cables from the twin to the DP34? And if I find out the distance is not too great can I run the 77 thru a DP Plus instead? I currently have the DP Plus on my 500 dish.
TheKrell
A mighty and noble race originating on Altair IV.
38,835
46,521
Fairfax, VA
If you have fewer than 3 receivers, you can dispense with the switch and simply run your dual into your DPP twin and you're done.
chainblu
634
100
How far is the 77 dish from the other Dish 500? I think Dish only approves 80ft, but I'm aware of several cases where the distance is well over 100ft
