DTC100 off air tuner problem
  • Thread starter Thread starter CU2000
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
CU2000
SatelliteGuys Guru
147
22
I have a DTC100 that has not been connected to an Sat antenna for a couple of years. When I put it away everything worked fine on it. I reconnected it & the off air analog or digital tuner will not find any stations when you do a search.
It seems unlikely that the tuner would just go bad. Is it possible that the receiver needs a software update to function properly? & if so how do you get it to download current software. The record shows last updated in 12/01
thanks in advance. I left if connected to sat & powered it off tonight.
Looking at adding two DirecTivo's to setup...
Digital distortion and picture freeze
