Dual LNB
T
txtom911
Thread Starter
11
My antenna has just a single LNB. Am I missing out on something? What are the reasons for the multiple heads on some antennae?
I use a multi-switch (2x4) to operate 4 separate receivers. A couple of my receivers have two tuners. Can I install a 2x6 on my system to supply all the tuners or is some other configuration needed?
B
bonscott87
925
You miss out on any programming off 110 and 119 which is primarily HD, spanish and standard def locals. That's with the triple LNB dish.
The new 5 LNB adds in 99 and 103 which carry MPEG4 HD channels.
damaged
damaged
2,605
South of Heaven
Like stated above, if you do not want/need internationals (spanish etc), or HD, you are missing nothing.
Yes, it is as simple as changing out the 2x4 with a 2x6 to feed more tuners.
T
txtom911
Thread Starter
11
Thanks and another question.
Thanks. Since I haven't moved to an HD TV yet, don't need any international programs and all the locals are currently being received, I guess there is no reason to upgrade to additional LNB's.
My DVR receivers have two tuners. If I connect to both tuners, does that get billed by DTV as two receivers? Will my bill for 4 receivers suddenly change to 6 if I connect to the second tuner on each?
V
VinPro
Aug 1, 2005
33
Clifton, NJ
No, each DVR is treated as one receiver whether you have one tuner connected or two.
Similar threads
C
Lnb
Replies
15
Views
1K
carnagez28
C
Stargazer
Replies
4
Views
1K
Daniel Hawkins
D
M
Replies
Views
405
detuch254
D
ken2400
Replies
Views
377
raoul5788
raoul5788
derint
Replies
4
Views
1K
TheTechGuru
TheTechGuru
  • txtom911
