DVBS-100 found Intelsat Americas 5 but...
yuhas
Hi, I am very new to FTA and Satellite reception. I bought a Kworld DVBS-100 PCI Card and am using a Directv Sony DSS Dish with what I believe to be a Universal LNB. This system had been set up for DirecTV. I have a signal strength of 100 picking up Intelsat Americas 5 at 97 degrees West and the DVBS software has seemed to find several FTA channels all at 11898 mhz but I have no picture or sound. Kworld's technical staff have not been very responsive after my initial email to them. Does anyone have any idea what is going on? Is it something I don't have set correctly or is it the card? Thank you! Any ideas of things I can try to receive a satellite with the most FTA satellites here in Westerville, Ohio 43082? :)
Alice
Hello and WELCOME to the SatelliteGuys.US FTA forum!
You will need a KU LNBF if the dish/LNB has been used for DirecTV (KU satellites use a linear LNBF and DBS satellites (DirecTV Dishnetwork) use a circular polarized LNBF). A bigger dish is also going to be needed for the IA-5 satellite (30" min.).
Here are the angles to all the satellites from your area!
Code:
                          OH 43082
           Latitude 40° 6.876'N Longitude 82° 54.630'W
                         Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Telstar 12   15.0W 104.7 111.9  8.1 -47.7
                     Intelsat 901   18.0W 106.8 114.0 10.4 -47.1
                     Intelsat 603   20.0W 108.2 115.5 11.9 -46.6
                            NSS 7   22.0W 109.7 117.0 13.4 -46.0
                     Intelsat 905   24.5W 111.6 118.9 15.2 -45.3
                     Intelsat 907   27.5W 114.0 121.2 17.4 -44.3
                   Hispasat 1C/1D   30.0W 116.0 123.2 19.3 -43.4
                     Intelsat 801   31.5W 117.2 124.5 20.3 -42.9
                     Intelsat 903   34.5W 119.8 127.0 22.5 -41.6
              AMC 12 & Telstar 11   37.5W 122.4 129.7 24.6 -40.2
                          NSS 806   40.5W 125.2 132.4 26.6 -38.7
                        PAS 6B/3R   43.0W 127.6 134.9 28.3 -37.3
                           PAS 1R   45.0W 129.6 136.9 29.6 -36.1
                     Intelsat 705   50.0W 134.9 142.1 32.6 -32.8
                     Intelsat 707   53.0W 138.2 145.5 34.3 -30.6
                     Intelsat 805   55.5W 141.2 148.4 35.7 -28.7
                            PAS 9   58.0W 144.2 151.5 37.0 -26.6
                         Amazonas   61.0W 148.0 155.3 38.4 -23.9
           EchoStar 3 & Rainbow 1   61.5W 148.7 155.9 38.6 -23.4
                 Estrela do Sul 1   63.0W 150.7 157.9 39.2 -22.0
                     Brasilsat B2   65.0W 153.4 160.6 40.0 -20.1
                     Brasilsat B1   70.0W 160.4 167.7 41.7 -14.9
                 Nahuel 1 & AMC 6   72.0W 163.3 170.6 42.2 -12.7
                        DirecTV 5   72.5W 164.1 171.3 42.4 -12.1
                            SBS 6   74.0W 166.3 173.6 42.7 -10.4
                            AMC 5   79.0W 173.9 181.2 43.4  -4.6
                          Nimiq 2   82.0W 178.6 185.8 43.6  -1.1
                            AMC 9   83.0W 180.1 187.4 43.6   0.1
                     Brasilsat B3   84.0W 181.7 188.9 43.6   1.3
                           AMC 16   85.0W 183.2 190.5 43.5   2.5
                            AMC 3   87.0W 186.3 193.6 43.4   4.8
              Intelsat Americas 8   89.0W 189.4 196.6 43.2   7.2
                 Galaxy 11/Nimiq1   91.0W 192.4 199.7 42.8   9.5
                     Brasilsat B4   92.0W 193.9 201.2 42.7  10.6
                        Telstar 6   93.0W 195.4 202.7 42.4  11.7
                        Galaxy 3C   95.0W 198.4 205.6 41.9  14.0
              Intelsat Americas 5   97.0W 201.3 208.5 41.4  16.1
                        Galaxy 4R   99.0W 204.1 211.4 40.7  18.2
                            AMC 4  101.0W 206.9 214.1 40.0  20.2
                            AMC 1  103.0W 209.6 216.8 39.2  22.2
                           AMC 15  105.0W 212.2 219.5 38.3  24.1
                          Anik F1  107.3W 215.1 222.4 37.2  26.1
         DirecTV 6 & EchoStar 6/8  110.0W 218.4 225.7 35.9  28.4
                          Anik F2  111.1W 219.8 227.0 35.3  29.3
                    Solidaridad 2  113.0W 222.0 229.2 34.2  30.8
                         SatMex 5  116.8W 226.2 233.4 32.0  33.5
          EchoStar 7 & DirecTV 7S  119.0W 228.5 235.8 30.7  35.0
  EchoStar 9/Intelsat Americas 13  121.0W 230.6 237.8 29.4  36.2
                       Galaxy 10R  123.0W 232.6 239.8 28.1  37.4
                        Galaxy 12  125.0W 234.5 241.7 26.8  38.5
             Galaxy 13/Horizons 1  127.0W 236.4 243.6 25.5  39.6
 Intelsat Americas 7 & EchoStar 5  129.0W 238.2 245.4 24.1  40.5
                           AMC 11  131.0W 240.0 247.2 22.7  41.5
                        Galaxy 1R  133.0W 241.7 248.9 21.3  42.3
                           AMC 10  135.0W 243.4 250.6 19.8  43.1
                            AMC 7  137.0W 245.0 252.2 18.4  43.9
                            AMC 8  139.0W 246.6 253.8 16.9  44.6
                     EchoStar 1/2  148.0W 253.3 260.6 10.2  47.1
        Satellite Finder is (c) Copyright 2004, P. Lutus
Are there Echostar 6/7/8 FTA Channels available using Circular LNB?
First, THANK YOU so much for your quick response to me and for the list of satellite names and locations! This is a great site!
If I cheap out and don't buy the 30" dish (is 36" really better for FTA in USA?)
and linear LNBF, can I pick up FTA channels on 110 and 119 Echostar 6, 7 or 8 using my current circular DirectTV LNB and Sony DSS Directv 18" dish?
Thanks again.
Alice :)
THere no free channel at those slots, and FTA DVB programming need minimum size dish or your signal will not be stable or no signal.
What you should know about Twinhan DVB
Maximum cable length?
