DVR-1100c pc playback issues
$660.00
fyretech
29
USA
When recording and just hitting the record button on the remote and letting it record for a couple of days, I then try to play the file on a pc. The results are mixed. The maximum recorded file size default by the dvr is 04:41:16.
I use media player classic (i test with other players also). Some DVR files play back well. Other files have error 'can't render file'. Others report ridiculous play times from 10 minutes to 100+ hours even though the file sizes are the same. This behavior is replicated with freemake, iwisoft...
Also, when I use freemake to edit the files it works well with the ones that report normal run time of 04:41:16. But obviously it freezes when trying to edit a file that thinks it's 50 hours long when it isn't.
Also, in freemake (I tried 5 files) all unedited 3ABN recordings say 'no audio' even though I can play them fine in MPC. iWisoft has audio, but it doesn't keep the filesize small like freemake ;[
I didn't notice anyone else having these issues.
I haven't tried playing back the original problem files on the DVR.
thanks
The oroginal files have normal play time on the DVR of 04:41:16 (+- 1-2 sec), and even shorter files that are not the full length experience the same variation on the pc posted previously, but play fine on the dvr. This is disappointing.
Glad to know that the files play back fine using the DVR1100c. I have never experienced or heard of this problem on a PC using Media Player. It seems that your PC is not reading the files correctly. Taking a wild guess ..... Maybe a formatting issue with your hdd or incompatibility with your specific PC configuration?
Have you tried playing the files on another computer? This might help you identify if the PC playback problem is caused by a corrupted file, drive indexing or the computer.
.TS file size is limited to 4GB. The actual time length of a recording will vary depending on the broadcast's bandwidth. A single .TS file at maximum size may contain +/- 4 hours of 2MB TV programming, but could have 60 - 80 hours of a 64 - 128k radio service.
The hdd is a 500gb WD passport, formatted by the dvr.
I tried playing the raw files on another pc, freshly installed MPC-HomeCinema.1.4.2499.0.x86.exe, same issue, the play time is reported from 10-100 hours for a 4 hour file with the problem files, the other ones that played fine were still fine.
Both PC's were XP os with DirectX 9.0c
fyretech,
The MPCSTAR player may work where MPC-HomeCinema failed? I don't know if it will but if you try it out let me know
MPCSTAR - Play all your Movies and Music!
I personally have not have good success on multiple brands of DVRs with the WD brand. Some models have severe indexing problems and a few develop problems as they fill up. i understand that the WD site has tools for many of their drives to modify the drivers for maximize compatibility. The best success for WD models has been with the units that support both USB and firewire.
Same issue with MPCSTAR.
I will try to get some other non-WD media to record and see if it replicates.
What about 3ABN no audio in freemake, this is consistent. What is the difference in audio between ADTV and 3ABN that freemake wouldn't recognize it?
thanks
thanks
I have no idea. I have not used 3ABN programming in Freemake only on ADTV. 3ABN does have AC3 audio in addition to the standard audio maybe that is the problem?
Which brand/size do you use? (that doesn't have indexing problems)
The DVR Hard drive sticky thread above are the specific models that I or other owners have tested. I am impressed with the SimpleTech S500U. It is a great inexpensive drive that works on every DVR brand that I have tested.
Not suggesting that your issues are 100% for certain due to the WD, but there are plenty of google references to issues with this brand on many DVR systems. Only testing will tell provide clues if your PC playback is related to the drive or not.
Brian,
It appears to me that Costco is one of the biggest retailer of the WD drives. I do not know the present buyers, (all my buddies were my age and also have retired!), but IF you would chose to get in contact with them at the Issaquah office, they may be happy to sell a line of HDs that they can promote as compatible with DVRs and PVRs. This would be especially true if they were competively priced - AND - available in COSTCO quantities.
If SaatelliteGuy who are Costco member would contact the buyers by the front line contact slips, it would also help!
POP
RV1Pop,
Thank you for the suggestion to work with WD to provide a DVR compatible HDD. We decided to keep it simple and only stock a 15GB starter drive that has no known compatibility issues and update the recommended HDD model as the availability changes for those customers wishing to have increased recording capacity.
DVRs, like the GEOSATpro DVR1100c, usually are provided with a very short list of suggested, tested and supported hard drives. It is important to note that the manufacturers often change programming in the external controller when they change to a different drive or OEM batch of the same model and the model suddenly becomes incompatible. A cat and mouse game!
In the past, I have spoken with WD highest level technical support / engineering and they have little interest in putting out a patch to dumb down their "Smart" external drives to specifically address incompatibilities with DVRs. The problem is not the WD HDD, it is the USB controllers that they put in their external cases which have OTT features. WD acknowledges that their OTT features may cause issues. but the DVR market is small-time in their big picture as they are pushing their own Expander technology and media severs. WD has released some patches that shut off OTT features in the controllers as it seems that these features also will cause issues with some PCs.....
The real reality check: It is impossible to sell against the big box stores on PC items, or electronics. Wholesale cost on a main stream brand external 500GB hdd is nearly the same as it is available retail at a big box store. We can't compete with big box stores in distributing and supporting off the shelf hard drives and charging a premium price to customers. The market is too small to distribute a custom DVR drive supporting the diverse equipment found in the FTA market.
Many HDDs out there that work great! Keep the list growing! Continued input on the compatible drive sticky thread for the GEOSATpro DVR1100c will assist new HDD purchasers a fresh list of available drives available at the lowest street price.
BTW... In addition to the list above of verified drives, I have had great luck with generic cases with no OTT features and any brand hdd up to 500GB. Haven't had a single incompatibility yet!
I bought the above hitachi at another store:
Micro Center - Hitachi 500GB X-Series 2.5" USB 2.0 Portable Hard Drive - HXSMNA5001 0S02520
I put it on ADtv, press the 'record' button, and let it run over night, the following day I edit what I want to keep and watch.
I still have a problem with files on the new HD. I formatted the hitachi on the dvr. I can play back the files on the dvr and media player classic.
When I try to convert and edit them to mpg in Freeplayer, then the full size 4gb files are good, but the files that I manually stopped the recording on the dvr, of which there are three, are mixed results:
1) first file is 1gb, and can play fine in freemake, and can moved the 'slider' around
2) second file is just short of 4gb, and can play in freemake, but as soon as I move the search bar to edit it, it freezes, as if it can't find it, and the LED on the HD stays lit
3)third file, same issue as second file
I haven't noticed this issue with manually stopped files before, so I will pay attention to them more. Perhaps I didn't wait long enough for the DVR to write before I unplugged it? Even though the LED on the HD stopped showing activity, indicating no recording going on, and the dvr display went from 'rec' to '111', perhaps there is some kind of lag?
Or there is a bug if the file is bigger than a certain size and the recording is stopped manually?
I still have files on my WD drive, and will check those problematic ones to see if they were also manually stopped or not (easily recognizable by the smaller GB size).
When pressing the stop button, the recording is finalized and "Please Wait, Saving Data" is displayed. If the USB is disconnected before the display disappears, possibly the file is not finalized correctly. All files have the same file headers, save and terminate identically.
All types of recorded files play fine on the DVR and using the media player app, Media Player Classic on your PC and I have used Video ReDo with the same success on these types of files.
Playback issues with FreePlayer might be better addressed by the developer of that program. Did you send Freeplayer support samples of the problematic files? They might be able to determine why the FreePlayer app is having issues with specific TS files when other apps are not.
Basic newbie question regarding setting the DVR manually.
Glorystar Welcomes New Channel - God TV
