Factory Setting VIA PC
sony1
52
Anyone know how to restore the AZBOX factory setting via a PC?
Do files exist to restore factory setting?
I think that if you FTP into the Azbox, delete the files all_channel.dat, antenna_list.dat, and DVBS.dat, then reboot the Azbox, the factory default values will be copied from the protected area of the DOM, and you will be essentially at factory default. This is just an observation from playing with the box quite a bit when I had one. It will not , of course, return the firmware version that came from the factory. You'll have to load that yourself , seperately, if that is your desire. Someone else may well have additional advice, I no longer have an Azbox to try it out on.
http_Streams.txt
USB Channel List for AZbox Elite
