Finding two of the three superdish birds...
parkerbender
I'm having a hard time finding the 119 sattelite on a 105 superdish. Originally i could only find 110, and after looking at the lnb's, i saw that the fss stacked lnb looked horrible and yellowed on the eye, so i replaced it, and then could get 105, unfortunatly, i still am only picking up a few random and my local channels... any help/ideas? i've about a 70 strength reading on 105 and am around 90 on 110... should i assume that 119 would be pointed since i have the other two sattelites? might the digital lnbf be junk?
thanks!!!
It could be a variety of issues. I'm assuming you have all 3 sat feeds going into a DP34 switch? If so, have you tried swapping around inputs, doing a checkswitch on your receiver, and seeing if the problem-child 119 follows? If it does, then chances are you either have a line of site issue (tree, shrub, etc) or the LNB crapped out.
Are redundant or mirror HD channels necessary?
Dish 322 and 3900 w/ dpp lnb problems
