FTA & Dish Network
jself1982
1,272
South Carolina
On my FTA w/ Invacom LNBF, can I aim the FTA dish at 129 or 105 or 121 or 118.8 and run this to my Dish Network receiver? If so, how would I connect it to the Dish Net recv. and would it blow up any of my switches?
Just curious.
Any of the 2 Circular outputs will work as a Dish legacy LNB (L.O. 11250)
It will not work properly if you have a Dish Pro system/switch!
The Invacom is a Legacy LNB so if you use DishPro (which according to your signature you do) it won't work.
I've tried it and it does work on a Legacy setup. If you run it directly to the receiver, do a check switch first to clear everything out, then hook up the LNB and rerun check switch.
I have a Legacy Twin so I attached a SW21 switch to the circular and could get 110/119/148. The only drawback is if I left 148 the receiver would go screwy 9so it wasn't worth it) :D
Apppadana INT Changing Transponers
Kuen-tv
