General Instrument
Tommyboy
338
13
What is the difference between the General Instrument 4DTV model
#920 and #922
4DTV Model 922 4DTV Model 920 Digital Sidecar Model 905
S-Video works on both analog and digital channels S-Video only works on digital channels only No S-Video output
25 timers 5 timers 5 timers
Updated IPG look & feel IPG (interactive program guide) IPG (interactive program guide)
Receives both SCPC & MCPC DigiCipher II Receives only MCPC DiiCipher II Receives both SCPC & MCPC DigiCipher II
Analog IRD can handle 36MHZ feeds Analog IRD can't handle 36MHZ feeds N/A (no analog receiver built in)
Base band output No base band output No base band output
Digital S/PDIF (coaxial digital audio out) No S/PDIF output No S/PDIF output
MMAP high definition/speed port to connect to HDD200 MMAP high definition/speed port to connect to HDD200 MMAP high definition/speed port to connect to HDD200
Remote controls the IRD, most TV's, VCR's & one other device Remote controls the IRD, most TV's & VCR's Remote controls the IRD, most TV's, VCR's & one other device plus has analog/digital mode button
Sony digital comb filter Specs N/A N/A
New processor that's faster loading IPG & other features N/A IPG initially displays 30 minutes offset from current time and usually one channel offset from current channel
Dual RCA audio outputs One pair of audio outputs Two sets or RCA composite outputs (both fixed volume)
Dual RCA video outputs One RCA video output Dual RCA video outputs
Different looking remote N/A The remote that ships with the 905 has UHF and IR capability, but the 905 itself is IR only
The Digital Era Is Here!
As you may have heard, there's a revolution going on in satellite entertainment. A digital revolution. Many of your favorite channels are converting their broadcasts
#920 and #922
The 922 is the newest one, and the one I would recommend, 920 is a pain with unplug replug and it can't get all the channels, the 905 is a slave to the old analog IRD and makes it hard to use or a hassle with the remotes, the 922 gets more channels and has better features, and will last longer if you buy one from NPS or Skyvision now, they are all brand new units with brand new batteries, getting a used 920 or 905 is not a good idea, unless the battery has been replaced, it lasts about 10-15 years, so a new 922 will be your best bet.
think i finally got everything all aimed correctly
Strongest C-Band satellite and transponder
