H20-100 / Aug. 10 & 11 / {CE:08:02} 0x202A
Brewer4
4,022
Hartford Connecticut
From DBSTalk.Com
LE Risks and Guidelines
How to Force Download an LE Release
Be sure to monitor the Living on the Edge forum HERE at Satellite Guys for changes in probability and go status!
H20-100 {CE:08:02} 0x202A - Announcement
Systems in this CE / Version
H20-100 {CE:08:02} - 0x202A
Window of opportunity to download:
Friday; August 10, 2007 11PM - 2:30AM ET
Saturday; August 11, 2007 11PM - 2:30AM ET
Current Probability: 50%
Be sure to monitor the threads and chat room to check on final availability
The Contents of the Release: (Differences based of Last National Release)
  • Items from CE:08:01
  • Items from CE:08:02
Improved
  • Stability
  • Guide speed performance
  • XM Channel Lockup (fixed)
  • UI Polishing
  • Software Version / Date in UI display corrected
Updated
  • N/A
New feature(s)
  • SWM Support enabled
  • INFO hold -> Jump to System Information Screen
  • Additional key presses on remote, will bring system out of standby
  • Program Guide now displays more then 4 characters of channel short name
  • One Button Guide Toggle
Notes
  • N/A
I asked Earl for clarification as nothing was in Red for the release, here are the updated things for this release:
Software version / date correction
One button guide toggle option
Everything else is the same as the previous test release.
The H20-600 is getting a national staggered roll out. Expect to see it automatically sometime over the next few weeks. So no CE's for a bit. But it will give you interactive and Sat 99 detection fix.
I have a question. Is it possible that my reciever downloaded an update by mistake? I was watching late last night (after midnight PST)and there was a power outage that lasted less than 5 seconds. I went to bed shortly after.
Today, the guide is a little erratic (slower) and I noticed that my signal strength that used to read 70 average is now over 90 average.
Also even though I have the standard channels set up as Pillar Box, it randomly stretches them to fit the 16x9 of my TV. If I go to guide and back it fixes but it's been annoying.
Any advise is appreciated.
Check your software version and see what it says. Menu - Settings - Info and Test and scroll down. You will see past update version and time.
Thanks. It does say it upgraded Tuesday at 2:22am Version 0x2021
Is there anyway to roll it back as it has just caused problems with the reciever?
Since 0x2021 is the national release, if you force download again, it will be the same version. Looks like you will have to wait for next release or try one of the Living on the Edge releases to fix.
Changing Zip Code
H20-100 / Aug. 17 & 18 / {CE:08:03} 0x1062
