H21 / H23 CE Release 3/27 0X42E0
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,055
457
Central Michigan
Systems in this CE
H21-100 • H21-200
H23-600
Software Download Windows:
Friday, March 27, 2009 11PM - 2:30AM ET
Saturday, March 28, 2009 11PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
National Release Candidate for H21
Moderate Risk H23-600
New features
  • 01 - Network
  • 01 - Media Share
  • 01 - Music Screen Saver
  • 01 - Game Search
  • 01 - 1080p/24
  • 01 - OTA via the AM21
  • 01 - Autotune
  • 01 - Multi-Room Viewing
    • [*]View Playlist from a networked HR2x or R22
      [*]Playback/Trick Play functions from any networked HR2x or R22
      [*]Press {LIST} to see HR2x or R22 servers
      [*]one playback per server at a time
  • 02 - Parental Controls when scheduling autotune
  • 02 - MRV: bookmarks and resume playback from previous location
  • 04 - Friendly name in network setup
  • 04 - QuickTune
  • 05 - Built-in Self Test
  • 13 - Advance setup in remote control
Improved/Updated
  • 02 - Support for more 1080p Sony TV models
  • 02 - Faster Guide scrolling
  • 02 - ATSC signal meter performance
  • 02 - Fixed a screen saver issue
  • 02 - ATSC setup screen now works on first boot
  • 02 - Fixed reappearance of deleted autotunes
  • 02 - UI updates ("tuner 2" and "tuner 3" references)
  • 02 - Fixed Gray Screen or a PPV OSD appearing overnight
  • 02 - Improved "Try Again" when trying to connect to the Internet.
  • 03 - AV1/AV2 remote code refinements
  • 03 - Improvements to DHCP network setup
  • 04 - Issues with rebooting while in standby
  • 04 - WGA600N Support
  • 04 - Static IP Setup
  • 05 - Stability
  • 05 - Missing "Just a few seconds" OSD
  • 05 - MRV playback and trickplay problems
  • 05 - User Interface polishing
  • 06 - Network services, Network setup, Network status
  • 06 - One touch autotune via Enter key
  • 06 - H21-100, SWM compatibility--will not affect other boxes
  • 06 - H21-100, remote control support
  • 06 - Removed "Reformatting Hard Drive" screen after Reset Everything
  • 06 - Changing Display Language
  • 07 - One touch autotune via Enter key
  • 07 - WGA600N setup with WPA encryption
  • 07 - Receiver not resetting
  • 07 - Closed Captioning Loss
  • 08 - Autotune on ATSC channels
  • 08 - WGA600N setup with WPA encryption
  • 08 - UI Improvements
  • 08 - Missing spending limit unlock OSD
  • 08 - SWM issue, Signal Strength H21-100
  • 08 - System test H21-100
  • 09 - Network Setup
  • 09 - Autotune on ATSC channels
  • 09 - Keyword search
  • 09 - Screen flash coming out of Standby
  • 10 - Improved Front Panel display on boot up
  • 10 - IR Remote H21-100
  • 10 - Remote setting when reset defaults
  • 11 - PPV spending limit conversion (compared to national release)
  • 11 - Video when switching to alternate audio
  • 11 - Fixed blank reset everything screen
  • 12 - Stability fixes
  • 12 - Faster keyword search
  • 12 - Reset everything warning message
  • 13 - Autotuning when using parental controls
  • 13 - Fixed "tune to 201" issue
  • 13 - Reset defaults correctly sets the hide/show SD duplicates option
  • 13 - Updated connection successful message in Network setup
  • 13 - Stability
  • 14 - Autotune Fixes:
    • [*]Manual with past start times
      [*]Lingering icon after canceling
      [*]Parental Controls
      [*]Minor polishing
  • 14 - Updated welcome screen and help messages
  • 15 - Autotune Scheduling with Viewing Hours set
  • 15 - Preserve favorites when converting from NDS to DIRECTV firmware
  • 15 - HDCP content protection H23-600
  • 15 - Minor polishing
  • 16 - Additional improvements to items from previous CE
Notes
  • Reverting back to National Release will go back to default settings
  • To enable MRV:
    • [*]Network must be enabled
      [*]Enable IAMANEDGECUTTER keyword
      [*]Select Menu -> Parental, Fav's & Setup -> Miscellaneous Options -> Multi-Room DVR and choose On.
      [*]Network must be enabled on HR2x and R22 DVRs
  • Please report non-MRV issues only
LGM
Feb 12, 2009
19
Amarillo, TX
Seems stable so far. I'm guessing the AM21 staying powered up is a permanant feature because it's still on when powering the receiver off. h23-600 & AM21. Haven't lost video when changing channels at all with this release.
Take care,
L.G.M.
LGM
Feb 12, 2009
19
Amarillo, TX
And again, spoke too soon. Lost video on all channels with a 721 error last night. Restarting clears it up, but it's aggravating - if only because it's so random. Only improvement I can see is that I'm at least getting an error message now instead of just a blank screen. I've moved this receiver to other locations in the house and still get the problem. So, I don't believe its a cable issue. Might be a faulty receiver.
Thanks,
L.G.M.
CE's for Thursday 3/26 - 3/28
HR Networking question
