HDMI Cable Quality
Shoot To Thrill
SatelliteGuys Guru
128
13
United States
I use cheap (under $6) cables and could never justify the more expensive options.
What are your thoughts on HDMI cables related to their cost?
I have purchased Amazon Brand and some from Monoprice, they are cheap and work fine.
Maybe when used with Hopper 3 and 4K there could be problems.
Dan
It seems to me that the cable issue would be the integrity of the plug itself, right? The material of the conduit the signal travels through makes no difference, since we're dealing with a totally binary signal -- it's either on or off.
Not necessarily. Interference can still cause corruption of the data stream in a poorly designed cable.
I've had one of the cheap ones from Walmart be intermittent, it didn't work unless you wiggled it.
I had some cables that caused "sparkles" on my PS3. After numerous back and forth cable swapping, I finally found a cable that worked.
Home media mp4 fixed U307
Change 722 remote address?
