HDMI questions...
NoCenterIceNoDishNetwork
SatelliteGuys Guru
Sep 18, 2007
137
Niagara Falls,NY
I want to be able to watch the 1080p and as I've heard it only accepts HDMI cables. I have a 52' Samsung connected to a 722. If I were to buy a HDMI cable would it anyway effect the audio or quality of this crystal clear Samsung and how? And what type of HDMI cable would you recommend for my setup?
old corps
1,707
21
Mid-Michigan
#1. NO
#2. ANY HDMI cable from monoprice.com
JMHO
Ed
Voyager6
*Cancelled*
17,097
5,323
Wokeville
How are you connected now?
#1. NO
JMHO
Ed
I second your opinion. Monoprice is great.:up
primetimeguy
1,003
39
St. Paul, MN
Yeah, it will effect the picture and sound. It will make it better.
not true.
Answer is it may be the same, better or worse. A lot of TVs have different internal settings for the different inputs so you might see differences in the PQ. And a bunch of people have reported washed out colors via HDMI vs component (me being one but I was able to fix the problem in my TV service menu).
So the only one that can say there is a difference is you. :)
lakebum431
16,474
4,222
Norris, TN
I should have got my HDMI cable from monoprice. I overpaid for mine at Tigerdirect. Paid over $30 for a 6" cable when I could have got the same type from monoprice for about $15.
Actually for less than $8 including shipping!
8bitbytes
3,239
NoVA
Some have reported receiving the 1080p over component cables.
I think you are talking about people being able to generically run 1080p over component, which is very possible. Being able to watch the 1080p24 VOD from Dish over component? Doubtful since HDCP is involved. You would need to connect an HD Fury to your DVR HDMI port and then run component to the tv for that to work.
Primus
234
St. Louis, MO
not true.
Well, it is certainly true for me. Otherwise I wouldn't have said it. All things equal, HDMI *should* provide you with a better picture then analog component cables.
8bitbytes
3,239
NoVA
All things being equal, they should be the same. There is nothing about HDMI that makes it better than component.
That's the key - all things being equal. But they rarely are. You have different colorspaces, different subsampling specifications, and different bit levels for the pixels being represented.
If the video processor for component is better than for HDMI or vice versa, you will see a difference.
Some people have better results from HDMI
Some people have better results from Component
Some people have the same visible result from either
SatelliteGuys Guru
Sep 18, 2007
137
Niagara Falls,NY
how do i know if i have component or HDMI? while i kow i dont have HDMI because the ports dont have a cable in them that say HDMI port 1 and HDMI port 2 neither does the receiver. But the only thing running into my tv is a power source and some Audio video cables ( like you use for your xbox)
primetimeguy
1,003
39
St. Paul, MN
Yep, I agree with you 100%. I was just trying to get people away from the thought that "it's HDMI, so it's better".
loves2watch
169
Mew Nexico
The HD Fury is for RGB TV connection not component.
8bitbytes
3,239
NoVA
HDMI
Component
Composite (non-HD, low res)
