help with a 10 footer
macgod79
305
Nc
Hey guys I'm a newbie.I've recently got my main components for my install I have aquired a dsr410 for my hits channels and I got a azbox ultra and I lucked out and found a 10 ft channel master dish.what pieces should I get as far as lnbf and cabling do I need to get.I gutted the electronics on the dish as I wanted to start fresh so id know what to do.what should I get
I would get a servo less lnb like the one on sadouns site. Either c or c/ku. As far as rg-6 cable, get solid conductor, its alot better.
I have a BSC621 lnbf and it has been working great! Others have had so so luck with them but most recommend the DMX741. Both lnbf's receive C band and Ku band and some sponsors here have them. If you go on Ebay and type in "C band lnbf" or "Ku band lnbf" the best deal is $24.99 with free shipping for the DMX741.
If you are setting up a BUD from scratch I recommend that you put the ole C band lnb on and find a strong satellite. After that then install the lnbf which usually involves a bunch of fudging around and luck to fine tune initially. Then find your true south and tweak and enjoy! :)
A quality RG6 coax is a must for satellite Tv. You are also going to need a way to move the dish to receive different satellites. Get a Gbox or Vbox to simplify things once you get all set up and running. For now I am using a DSR922 and piggybacked my Openbox until I get a V or Gbox!
Do I need any special wire to the motor.whats a good motor for the dish.
Anthony G?
found another bud!
