Help
marvinhartw
4
I have lost gmt it says scrambled or bad channel. Signal level is 99% on transponder 11860. Any help would be appreciated :mad::mad::mad:
I should have said the gospel music channel not gmt. I did a channel delete and then a blind scan and still no GMC. I receive all the other channels on this transponder #11860 but not GMT . any ideas!!!
I'm not at home so I cant scan it...hopefully someone else in the interim can check
Also did you say scan all not FTA?
Found it
I found GMT it is listed as TV4 on my drop down menu. I was on the web site and had to compaire the broadcast as the emblem on the TV is hard to see. Thanks a bunch for your help:):):):)
nope not seeing things. Well you ARE seeing GMTV :)
Hopefully Glorystar can fix the name of the channel so it shows the right name like it use to
Antenna Moving
Hope Channel transponder?
