Hopper 3 with Hopper plus internet connection problems
mheisen
34
19
Over the past few weeks, I have had problems connecting to streaming services (Netflix, HBO et al). When I go to the TV's native Channels, I have no problem. The Dish internet troubleshooter shows I have a good internet connection. I'm wondering whether it's an issue with my internet provider or a problem with the Dish software on the Hopper Plus. Anyone else seeing this?
I have a DISH Hopper 3 (Software H713) with Hopper Plus (Software P15403). I have not tried streaming services but I primarily watch TVB Jadeworld international package which is only available by streaming and when I have an issue, I usually have to go to a non-streaming satellite channel first before the streaming channels will work again. What software versions do you have and what is the error message if any are showing on your screen? or is that Dish downloading logo just stuck and never finishes?
I'm on H713 on the Hopper and P15403 on the Hopper Plus. It shows internet connection issues and doesn't finish loading the various services. I see the "loading circle going around. Sometimes I get a message saying that the service is having trouble loading my content and to check the internet connection.
Did it ever work correctly before? Hard to say what the problem is. Usually for streaming, it will show the Dish logo with lines sweeping down to show downloading, never seen the circle issue. Did you try a manual reboot, red button reset, power cord unplug/replug to see if it makes a difference.
Might be worth just to ditch the hopper plus. No issues here on h713
Buy a roku and dump the hopper plus you'll be better off. If you have a smart tv you don't need either one. No hopper plus here and no issues!!!
I have a Hopper Plus and no issues either. charlesrshell has both a Hopper 3 with Hopper Plus and one without, he doesn't have the same issue. Before blaming it on the Hopper Plus, he should see if the problem still exists without the Hopper Plus connected as it could be the Internet connection itself or some setting in the router itself. There is someone in another thread who has EHD issues on the Hopper 3 only setup but does not have the EHD issues on the Hopper 3 with Hopper Plus and he has already tried swapping the EHD and it did not make a difference so like the saying, YMMV.
The Roku costs $$$, Hopper Plus is free. That may not be the only costs as it depends if the TV in question still has available HDMI ports and if not, it will require a HDMI switch and HDMI cable which adds more to the cost.
I have a LG 3D OLED Smart TV and I still need either of them because it does not have Android TV built in. Add a Hopper Plus and see if you actually have issues or not as until you actually tried it, it means nothing.
If the OP has a router and a managed switch, that could be the problem.
I have a Hopper 3 and 5 Joey 4s. I recently updated my Router, Switch and access points with Ubiquiti UniFi gear. I had an issue where the switch interpreted the communication between the hopper internet connection and one of the Joeys as a data loop. I had to change some settings in the switch to re-enable that port. Your router could possibly be doing the same thing blocking the connection.
If your router has a malware connection setting, try disabling it temporarily, and see if the internet comes back. Contact your ISP and see if there is a block happening at the router or switch level, or via the ISP's threat protection.
Dish Bankruptcy - Business as Usual
