Hopper 3 with Hopper plus internet connection problems
mheisen
34
19
Over the past few weeks, I have had problems connecting to streaming services (Netflix, HBO et al). When I go to the TV's native Channels, I have no problem. The Dish internet troubleshooter shows I have a good internet connection. I'm wondering whether it's an issue with my internet provider or a problem with the Dish software on the Hopper Plus. Anyone else seeing this?
I have a DISH Hopper 3 (Software H713) with Hopper Plus (Software P15403). I have not tried streaming services but I primarily watch TVB Jadeworld international package which is only available by streaming and when I have an issue, I usually have to go to a non-streaming satellite channel first before the streaming channels will work again. What software versions do you have and what is the error message if any are showing on your screen? or is that Dish downloading logo just stuck and never finishes?
I'm on H713 on the Hopper and P15403 on the Hopper Plus. It shows internet connection issues and doesn't finish loading the various services. I see the "loading circle going around. Sometimes I get a message saying that the service is having trouble loading my content and to check the internet connection.
Did it ever work correctly before? Hard to say what the problem is. Usually for streaming, it will show the Dish logo with lines sweeping down to show downloading, never seen the circle issue. Did you try a manual reboot, red button reset, power cord unplug/replug to see if it makes a difference.
Might be worth just to ditch the hopper plus. No issues here on h713
Buy a roku and dump the hopper plus you'll be better off. If you have a smart tv you don't need either one. No hopper plus here and no issues!!!
I have a Hopper Plus and no issues either. charlesrshell has both a Hopper 3 with Hopper Plus and one without, he doesn't have the same issue. Before blaming it on the Hopper Plus, he should see if the problem still exists without the Hopper Plus connected as it could be the Internet connection itself or some setting in the router itself. There is someone in another thread who has EHD issues on the Hopper 3 only setup but does not have the EHD issues on the Hopper 3 with Hopper Plus and he has already tried swapping the EHD and it did not make a difference so like the saying, YMMV.
The Roku costs $$$, Hopper Plus is free. That may not be the only costs as it depends if the TV in question still has available HDMI ports and if not, it will require a HDMI switch and HDMI cable which adds more to the cost.
I have a LG 3D OLED Smart TV and I still need either of them because it does not have Android TV built in. Add a Hopper Plus and see if you actually have issues or not as until you actually tried it, it means nothing.
If the OP has a router and a managed switch, that could be the problem.
I have a Hopper 3 and 5 Joey 4s. I recently updated my Router, Switch and access points with Ubiquiti UniFi gear. I had an issue where the switch interpreted the communication between the hopper internet connection and one of the Joeys as a data loop. I had to change some settings in the switch to re-enable that port. Your router could possibly be doing the same thing blocking the connection.
If your router has a malware connection setting, try disabling it temporarily, and see if the internet comes back. Contact your ISP and see if there is a block happening at the router or switch level, or via the ISP's threat protection.
Can you share what settings you had to change?
Required Inbound & Outbound Network Ports
The standard ports designated for DISH Hopper configurations include:
    • TCP Port 80 – HTTP communication
    • TCP Port 443 – HTTPS secure communication
    • TCP Port 5678 – Neighbor Discovery / Device Sync
    • UDP Port 80 – Alternative streaming/network data
    • UDP Port 443 – Alternative secure media streams
    • UDP Port 5678 – Remote pairing and network discovery
Critical Network & Security Considerations
    • UPnP (Universal Plug and Play): Enabling UPnP on your router is the easiest way to allow the Hopper to automatically handle its own port maps.
    Internal Communication (MoCA & Local LAN): The Hopper Plus and Joeys communicate internally over your local home network using router's default internal traffic policies. Local firewall software or strict internal VLAN isolation can block the Hopper 3 from seeing the Hopper Plus or Joey extensions.
    The other thing is that these are streaming channels which was why I asked if they have worked correctly even without the Hopper Plus as checking the post history of the OP, it appears that the Hopper Plus was added around 1/2 a year ago and from looking at my own Internet settings portion, all the Hopper 3 does is really measure signal strenth for WiFi and probably just check ping times to show it is connected or not to the internet, it does not check the actual speed or latency. Since the OP has a Hopper Plus, OP can always install the Speedtest app for diagnostics and then take a photo of the results and post it here. Before 2017, I used tȯhave 6Mbps/768Kbps ADSL and even though the Hopper 1 and Hopper 3 also showed internet connectivity is okay, everytime my Ring Doorbell is uploading, it would knock the entire internet connection off-line as the upload pipe would be 100% filled by the Ring Door bell uploading the video because the ACKnowledgement packets would not have priority being sent back in time which was fixed with QoS traffic shaping but that still does not mean streaming will work as it requires at least 25Mbps minimum or more if there are other devices on the same connection sharing the bandwidth.
    • Internal Communication (MoCA & Local LAN): The Hopper Plus and Joeys communicate internally over your local home network using router's default internal traffic policies. Local firewall software or strict internal VLAN isolation can block the Hopper 3 from seeing the Hopper Plus or Joey extensions.The other thing is that these are streaming channels which was why I asked if they have worked correctly even without the Hopper Plus as checking the post history of the OP, it appears that the Hopper Plus was added around 1/2 a year ago and from looking at my own Internet settings portion, all the Hopper 3 does is really measure signal strenth for WiFi and probably just check ping times to show it is connected or not to the internet, it does not check the actual speed or latency. Since the OP has a Hopper Plus, OP can always install the Speedtest app for diagnostics and then take a photo of the results and post it here. Before 2017, I used tȯhave 6Mbps/768Kbps ADSL and even though the Hopper 1 and Hopper 3 also showed internet connectivity is okay, everytime my Ring Doorbell is uploading, it would knock the entire internet connection off-line as the upload pipe would be 100% filled by the Ring Door bell uploading the video because the ACKnowledgement packets would not have priority being sent back in time which was fixed with QoS traffic shaping but that still does not mean streaming will work as it requires at least 25Mbps minimum or more if there are other devices on the same connection sharing the bandwidth.
This was for port settings for the switch, not the router.
Originally was recommended to use EDGE vs. Infrastructure, but had to change that back to Infrastructure.
Had to leave STP (Spanning tree protocol) ON, but disable BPDU guard, and also had to disable Non-STP loop protection.
The previous settings were flagging normal dish system packets as a data loop, and fully blocked that port on the UniFI Pro Max 16 POE switch.
These were specific to my managed switch, and may not apply to the OP's issue.
Yes, a switch unlike what the consumer calls a router does not use NAT (Network Address Translation. There could be other settings in the router itself that may have a effect as well. A router does contain a Layer 2/Layer 3 switch as well. A Managed switch does contain a Layer 2/Layer 3 router as well, just not the NAT type of router.
I have both HP/Aruba and Cisco Managed 1GBit and 10Gbit switches and never had any of the issues mentioned as my modem goes into the switch first while the router(s) all are connected to the switches. As for the OP, until we know his configuration and whether it ever worked with the Hopper Plus or without the Hopper Plus and just the Hopper 3 only, it would be hard to know where the issue lies since it could be a issue with the provider, bandwidth or the network hardware configuration among other things.
Wireless Joey4 (Android TV)
