Hopper/Broadband/MoCA Question
makman
Hi All,
Just got my 2 HWS 2 weeks ago. I have CAT 5 going to both HWS's. Realized yesterday that 1 HWS wasn't on DRA. Turned out that the network cable was loose at the router.
However before I realized the problem I checked the broadband setting on the receiver. Initially unbeknownst to me I was in the MoCA broadband settings by default as there was no ethernet connected at that point. I had 3 red bars and no connection. I tried resetting and renewing, red button reset, and unplugging the receiver, all to no avail.
I thought that if 1 receiver was connected to the net (which I had), it would share broadband via MoCA with the other receiver. Is that not correct?
Thanks,
Mitch
satnewb
1,480
691
New Baltimore, MI
Bridging needs to be enabled on the connected hopper. It may be off by default.
If you go into that same broadband sub-menu and hit the blue shortcut button twice it will pull up a hidden bridging icon.
Loved those old Expos uniforms.
Avail
Feb 28, 2013
10
CA
It should if you enable "bridging" on the hopper that is connected to the Internet. Bridging is disabled by default, I believe. It was on mine.
Avail
Feb 28, 2013
10
CA
If you have bridging enabled you should not have Ethernet connected to any other hoppers/joeys except for the one with bridging enabled. I believe it would cause ip conflicts unless the software has been updated to use one over the other. I've never tried it, but have heard of people who have had problems doing so.
Also as a side note, after I enabled bridging I had to reset the hopper via the red button on front and unplug the power from all joeys before everything worked correctly.
mitchflorida
972
94
What equipment do I need to complete a MoCA connection? I have a DECA device from DirecTV, will that work with Dish or do I have to purchase something else?
mitchflorida
972
94
I have a Hopper in the living room , a Joey in the bedroom and router and PC in the office. There is already a coax cable run from the router to the Joey. What do I need to do to use MoCA instead of using wi-fi? And would MoCA be much better than using wi-fi?
lucky86
3,941
179
By the sea, in a land called Honalee
The Moca would be faster, is that coax actually connected from router to joey? I would look closely and confirm that. Just hook the coax line from the joey to the client port on node to use Moca.
mitchflorida
972
94
No, there is just the coax cable sitting next to the router and the other end sitting next to the joey. They aren't connected yet. What interfaces do I need buy to connect them to router and joey?
lucky86
3,941
179
You don't connect it to your router, you connect that end to the node that the tech installed. Just be sure to connect it to the client port on the node.
Moving Dish Antenna: Advice Needed
